    Results 1 to 7 of 7
      Dec 2016
      71 Camaro With LSA Wants To Add Flex Fuel
      Hi My Pro Touring Friends
      I am almost done with my build and wanting to add a flex fuel kit to
      my 71 Camaro LSA.
      Has anyone here added a flex fuel kit to their vehicle thats similar to
      my car and if so do you have any photos of the install?
      Dec 2012
      Quote Originally Posted by 71CRumble View Post
      my 71 Camaro LSA.
      I added flex fuel on my '72 Stingray build, which has an LS3 416 powered by FAST XFI. It was covered in Vette Magazine: happy to post a link if that would be helpful.
      What ECU are you running? First step would be to confirm that your ECU has the capabilities to add FF.
      Jan 2017
      Los Angeles
      I’ve got flex fuel on my 67 camaro, just mounted the sensor on the firewall and used ptfe fuel line
      Jun 2015
      Flex fuel is a wonderful convenience and power adder. I've used it many times on the LSA and it's great.
      Feb 2011
      dallas, tx
      Simple. If your using a e67 ecu. I’m running a innovate wideband gauge. I then split the flex fuel signal and run it to the ecu blue connector pin 5 if I remember correctly.
      Aug 2017
      Reno NV
      Mine isn't together yet, but I'm using an AC Delco flex fuel sensor with a Holley Dominator ECU for procharged 540 BBC
