      ZZ383/SP383 Hydraulic Roller Cam P/N 19210723
      Came with the HT383 short block I ordered. Never been run. I'm using a different cam for my build. For late model roller blocks.
      GM P/N 19210723
      $275 or better offer.
      ​​https://www.summitracing.com/parts/nal-19210723
      Price does not including shipping.
      can email me at [email protected]
      1971 Camaro
      bump... someone can make me an offer
      Cam specs..
      Intake Duration at 050 inch Lift:
      222
      Exhaust Duration at 050 inch Lift:
      230
      222 int./230 exh.
      Intake Valve Lift with Factory Rocker Arm Ratio:
      0.509 in.
      Exhaust Valve Lift with Factory Rocker Arm Ratio:
      0.528 in.
      0.509 int./0.528 exh.
      Lobe Separation (degrees):
      112
      1971 Camaro
