Results 1 to 12 of 12
Thread: 275's on '65 Malibu?
10-11-2021 #1Registered User
- Nov 2006
- Austin, TX
- 41
I'm looking at a local car, a 65 malibu, that really has my attention. My one big hang up is I like to fit a moderately wide tire. (not wide like some of you crazy guys here...) Specifically a 275/40/17 or 275/35/18. Hopefully on a 9.5 but maybe a 9" wide wheel.
all my reading indicates the '65 malibu wheel wells are pretty small. However, all the details are from malibu/chevelle enthusiast forums that have no interest in cutting up their cars.
Other than the "how much do you want to spend" response, how feasible is it to fit 275's square on a '65 'bu?
For the back: I hear some 275's may fit very tight. I may expect trimming and rolling fender lips and perhaps mini tubs. I don't know if the frame itself is a clearance problem.
for the front: I don't know. most seem to be running 225's or 245s max. for mashing in the 275s it depends on where the tires rub or have clearance issues. If it is all sheet metal, especially the inner fender well, then i can fabricate partial inner 'tubs' for clearance. But if the outter fender itself is the problem given ample inner fender clearance then flaring or stretching the fender may be out of the question for me.
Any input from those familiar with these cars and where the tight spots are and how to address them?
18's might be good if they clear the tie rod and allow more backspace.Morgan
'87 Monte SS
10-11-2021 #2Registered User- Join Date
- Nov 2006
- Austin, TX
- 41
oh, the plan would include aftermarket front upper control arms, 1" taller lower ball joints, maybe 0.5" taller upper joints, ~1-1.5" overall lowering, stiffer spring rates, about -0.75deg static camber.
Morgan
'87 Monte SS
10-11-2021 #3On my 65 convertible I have 235/35r19 on 8” wheels in the front and 255/35r20 on 8.5” wheels in the rear. I had 235 and 255 17’s previously, so the over all tire dimensions stayed about the same. The car is lowered several inches all around. I think it would be hard to fit anything much wider in the front. The fronts would hit the sway bar when turning if I went wider and if I pushed them out any further they would hit the fenders, especially when turning. Im not sure if the convertible rear wheel wells are the same as a hard top, but I do have a little room to spare in the rear. A 265 would be easy if my backspace was adjusted inward. A 275 might fit but would be pushing it on stock wheel wells. Also keep in mind, because of the very low wheel opening on the quarter panel it is very difficult to get the wheels on and off.
10-12-2021 #4
