08-30-2021 #1Registered User
- Mar 2011
- 25
Noise/possible vibration at approx 55 miles per hour......ideas?
Hi guys,
I have a 68 Camaro - running full ridetech suspension (4-link coilovers and control arms).
Has a rebuilt 700R4 transmission, that was shop fitted, along with shortened driveshaft to suit.
Diff is a 12bolt, also rebuilt at proper shop. Has been done twice in fact, at two different shops.
Given the project has gone on so long, my memory may not be perfect, but will give you the run-down of my recollection of the sequence of events.
Soooo.....
I am currently getting a noise from the rear of the car.
At around 55 miles per hour on the freeway, I accelerate, then take my foot of the gas a little, and I get a sound, seems like a vibration noise, coming from the rear end. The same sound is not evident at slower speeds, more so at freeway speeds, more pronounced when I step off the gas. Suburban street speeds I still get some diff noise (unfortunately there is a whine from the new gearset), but it is nothing like the freeway noise. Seems the freeway noise is different to "gear whine".
As I said, had by diff built twice. First guy I did not trust had done right things. Diff was presenting as noisy, I was not happy with it. Long story. Thought noise was all related to a bad diff build, bad gears etc (some of it was) but given it has been done twice, and this noise still persists....clearly something else.
I "think" sometime during the 1st diff build, I upgraded my heim ends to the ridetech R-Joints. Now what I am not 100% sure about is if the noise started happening after the R-joints were fitted, or if it was present before. So many changes happening to the car, so many rattles and noises getting sorted....all blurs in my memory a bit. Plus it was not getting driven as much, so not 100% on the when the worst of the noise started.
So....
- Does anyone have any issues with rear end noise with R-joints fitted? I am wondering if their design lacks some noise isolation qualities? Or maybe could produce a noise at speed like mine is doing?
- Anyone else experienced a noise like this? Sounds like a vibration noise, but only at speed and more pronounced on deceleration. If I did not have new gears, I would honestly think it was some sort of mesh noise from really old, loose ring and pinion.
- Everything at the back of the car seems tight. Drive shaft - cant see any play. Maybe it needs re-balancing, but would have though driveshaft wobble noise would present differently?
Any advice appreciated.
Shanan
