Results 1 to 17 of 17
08-20-2021 #1
Ideas for clutch pedal stop Gen 1 Camaro
Hi guys, does Anyone have any DIY ideas or references for a clutch pedal stop for a first Gen Camaro using stock pedal assembly?
I found a very old teetoe jones reference using 3/8 nut bolted to the firewall but it seems a little dated.
Ideas appreciated..
"We recommend an adjustable clutch pedal stop be installed on the floor of the scar to stop the pedal from bottoming out the clutch master cylinder. This is necessary to avoid bending the shaft. A simple 3/8” coupling nut bolted or welded to the floor will allow you to adjust a bump stop or bolt and jam nut to achieve the proper pedal travel."
67 Camaro In progress
