      Nov 2016
      Sulphur, La
      C6 Z06 brake caliper, can I swap left to right
      I have been unable to source a front right red caliper. It appears that I can use a front left and swap the bleeder & the hard tube locations. Does anyone know if this is correct?
      May 2010
      kitchener,Ontario,Canada
      99 percent yes ...
      Ryan Austin
      On twitter @raustinss
      On Instagram austinss70
      Nov 2016
      Sulphur, La
      I really think so as well so I bought one. Got COVID now so may be a it before I test it
      May 2010
      when I took mine apart I labeled them left and right but honestly I don't recall seeing much difference if any at all
      Ryan Austin
      You just need to swap the bleeders and the crossover.
      SoCal
      Differential Bore Sizes
      Just a quick addendum to this topic:
      One of the features that makes a caliper directional is differential bore sizes, a feature used to reduce pad taper. This just means that the caliper pistons go from smaller to larger as the pad goes from leading to trailing. If you were to mount a caliper with differential bores on the wrong side, the differently-sized pistons would work to make pad taper much worse.
      This is not an issue on the PBR C6 Z06 calipers where all of the pistons are the same size. (6x 33mm)
      Brett H.
      1979 Pontiac Firebird Trans Am
      1991 Mazda Miata
      2005 Ford Mustang GT
      1987 Ford Mustang GT - Sold 06-29-2014
      1988 Oldsmobile Cutlass Ciera - RIP 9-17-2011
      1992 Chevrolet Corvette - Sold 10-12-2017
