    Results 1 to 13 of 13
      Apr 2011
      mass
      Aluminum 5.3 lc9
      All aluminum lc9 with all new cam,rod and crank bearings. Crankshaft polished , New rings,fresh hone, .585 lift cam, new ls7 lifters new lifter trays,new timing chain,gears ,oil barbell upgrade. New head gaskets,ARP head bolts . Pac 1218 springs,trunnions upgrade , new valve seals. New rear main seal. New timing cover gasket, new oil pump. Never been ran since assembled. I can install the stock oil pan and pickup(currently not on)Built for a project And need to sell to fund a transmission for my nova. Will include stock gen 4 intake and ecu. $2700
      Also have a gen 4 6.0 rec port head (cast iron block) for a $1000. Needs to be rebuilt.,think it had a bad lifter. Located in mass
      On me if interested and I can send some pictures.
      Las Vegas, NV
      Paul, what condition are the blocks in? Being from Mass.
      you looking at shipping at all?
      Thanks, Jeff
      Apr 2011
      mass
      I would ship.blocks are in good shape.on the lc9 I tapped everything and hot tanked the block. The lc9 block was hot tanked and cleaned.
      Feb 2017
      New Mexico
      PM Sent
      Apr 2011
      mass
      Apr 2011
      mass
      Apr 2011
      mass
      Bump
      Apr 2011
      mass
      Price drop to $2500. I am putting the timing chain /oil pump and covers back together and will take updated pictures
      Apr 2011
      mass
      Bump b/0
      corona,ca.
      shipping 6.0 to 92707 zip thanks
      72 chevelle.
      Apr 2011
      mass
      6.0 is sold. The all aluminum 2012 5.3 is left. I can ship through fastenal $2500 shipped to you local fastenal
      Apr 2011
      mass
      All aluminum lc9 5.3 is available. 58x gen 4 . new rings,main,rod and cam bearings all new. New timing chain and gears. New Arp head bolts,new ls7 head gaskets and lifters. Trunion upgrade,pac springs, new valve seals,.585/.585 camshaft. DoD Deleted and 3 bolt camshaft installed. Make an offer
      Las Vegas, NV
      Quote Originally Posted by 66larkgs View Post
      who built it?
      Shipping to Las Vegas, NV (Fastenal isn't shipping between coasts right now ??)
      Thanks, Jeff
