      Oct 2011
      Raingear Wipers with AAW kit
      Hey guys,
      Im trying to figure out where to get the power wire from the AAW harness to power the Raingear wipers. Power wire must be in the cabin. The AAW kit has a power wire for the wiper motor which is fused but it exits into the engine bay. How do I get this wire in the cabin? This is for a 69 Camaro
      I would probably use the brown ACCY1 wire in the accessory harness.
      Apr 2018
      The AAW classic update kit provides 4 wires to the wiper motor. Call them power, low, high, & wash.
      The Raingear setup needs 5 connections at the motor...power, low, high, park, and ground.
      I'd access the wiring at the fusebox/bulkhead. Locate the power wire for the wipers (yellow or white i believe),
      Remove that terminal from bulkhead, add additional wire to reach wiper switch. Reterminate with female terminal, reinsert into bulkhead. This will be power at wiper switch, 'B' terminal.
      Repurpose the 'wash' wire, connect to 'P' terminal at switch. Add a ground wire at the wiper motor to body
      Are you running a washer pump? The lighting side of the bulkhead has open terminal positions you can use
      for the pump.
      Mark
      Oct 2011
      Mark thanks, but that seems super complicated because I’d have to take apart the fuse block. It’s much simpler for me anyways to just use the acc1 circuit since there is already a fused power wire in the cabin. I was trying to see if there is a power wire in the cabin specifically for the wiper motor/washer, but it seems like there is not.
