    Results 1 to 11 of 11
      Nov 2018
      Winston Salem, NC
      L99 friction ring/ seal Question
      Pulled the balancer on an L99 crate engine today. This ring/ seal looking thing came out with it. It fits perfect on the end of the balancer snout.
      What is it and what does it do?
      I'm installing a Holley mid mount setup which uses a different balancer... Would you use this thing or leave it off?
      Thoughts???
      Nov 2018
      Winston Salem, NC
      PicsName:  20210525_201200.jpeg
Size:  17.0 KBName:  20210525_201154.jpeg
      The L99 had VVT and AFM. That looks like a spacer to accommodate the deeper front cover. Post a picture of the front cover.
      Nov 2018
      Winston Salem, NC
      Yes, it had the VVT and AFM. It had the cover with the phasers thing. I did the VVT/AFM delete new LS3 front cover, valley pan, 3 bolt cam etc.
      Nov 2018
      Winston Salem, NC
      Old cover and vpName:  20210525_223750.jpeg
      Then you can just install the balancer that came with the mid mount.
      Nov 2018
      Winston Salem, NC
      That makes sense.
      Still kinda curious on its purpose though.
      Here's a link to what I'm talking about.
      My first time seeing this on an LS engine...
      https://www.speedinc.com/crankshaft-...on-washer.html
      Nov 2018
      Winston Salem, NC
      Looks like a provision there for a keyed crank also.
      Quote Originally Posted by KnightmareZ View Post
      It's a multi purpose spacer.
      Nov 2018
      Winston Salem, NC
      I'll measure it's thickness tomorrow.
      I just think with the diamond impregnated material the design team probably was factoring more than spacing alone.
      Interesting, none the less.
      Nov 2018
      Winston Salem, NC
      .0015
