    Results 1 to 12 of 12
      1967-1969 Camaro Chassisworks Suspenison
      Full Chassisworks protouring suspension for 1967 1968 and 1969 Camaro
      I bought this suspension in 2012 and installed in the car, the project stalled and the car has sat inside since 2012. I am finally getting the project going again. The car is going to be taking a different path now and so I have removed this suspension and I am looking to sell it. This has been powder coated and installed in the car but never driven.
      What you are gettting:
      Front Suspension
      Chassisworks complete front subframe powder coated black
      http://www.cachassisworks.com/p-696-...uspension.aspx
      Chassisworks g-machine front clip suspenison
      http://www.cachassisworks.com/p-3661...uspension.aspx
      Chassisworks LS motor Mounts
      http://www.cachassisworks.com/p-3801...rd-offset.aspx
      Chassisworks front strut bars (does need firewall plates and tabs available from Chassisworks)
      http://www.cachassisworks.com/p-2693...130-steel.aspx
      Chassisworks G connector Support
      http://www.cachassisworks.com/p-3116...t-bolt-in.aspx
      Chassiworks bolt in subframe G connector
      http://www.cachassisworks.com/p-3108...r-bolt-in.aspx
      Chassisworks Drive shaft loop
      http://www.cachassisworks.com/p-1593...r-support.aspx
      Varishock bearing eye double adjustable Coil Overs
      http://www.cachassisworks.com/p-930-...25-travel.aspx
      Chassisworks T-56 Trans crossmember
      http://www.cachassisworks.com/p-2214...6-6-speed.aspx
      Rear Suspension
      Chassiworks Canted 4 Bar G-link with pivot ball
      http://www.cachassisworks.com/p-1299...uspension.aspx
      You would need to buy part numbers 5355, 5366 and 3148-263.38-094, these are the frame rail brackets and bolts. These are welded in my car and are not salvageable.
      Chassisworks Fab 9 rear end housing for splined sway bar, powder coated black
      http://www.cachassisworks.com/p-803-...aled-ends.aspx
      Strange Engineering 3rd noular 3rd member with Eaton Trutrack, 3.89 gears, 31 spline axles
      Chassiworks splined sway bar
      http://www.cachassisworks.com/p-1310...-roll-bar.aspx
      Varishock bearing Double adjustable coil overs
      All of this new would cost over $14k! Asking $10,000 buyer pays shipping, or depending on location we might be able to arrange a meet halfway delivery deal. Located in Fort Collins CO.
      I also have a Baer Pro + 14" Front and SS4+ 13" Rear (Red) Brake kit and stainless headers that I had intended to re-use however if someone is looking for a package I would also sell those.
      Jun 2017
      Pm sent
      Sending it back to the top....
      I'd love to do this for my car, but I'm recovering from my engine swap this past winter. GLWS, great deal for someone.
      Nov 2009
      Austin Texas
      What offset wheels and size wheels does this setup call for?
      I had 18x9 5.25 BS in the front bad 18x12.5 5.5 BS with mini tubs in the rear.
      Still available? PM sent
      If you decide to part anything out, I am a buyer on a few things. Text or call me PM'd my number
      Oct 2016
      PartOut
      I would be in for the center section and possibly the brakes if you decide to part out
      NoSleeperII - 62 Chevy II - SOLD
      NoSleeper68 - 68 Camaro - daughter
      NoSleeper71 - 71 Camaro - son
      NoSleeper90 - 90 Foxbody - to be determined
      All pms replied to, sorry for the slow responses. I have been waiting on a set of replacement rear frame brackets so that the package is complete.
      PM replied to.
      Sale pending, thank you everyone for the interest. Will repost if anything falls through.
