    Results 1 to 20 of 21
      Jan 2016
      Arizona
      Driveline shakes BAD
      For the past year that I’ve driven the truck since I got it finished, it’s had a horrible shake past 70mph. So violent the car acts like it wants to come off the ground. It’s starts in the shifter, then the whole car shakes. We’ve changed pinion angles, tires, wheel balance, driveshaft balance (which I think wasn’t done correctly) today I took the driveshaft out and this is what I found. Does this look normal for 3000 miles?Name:  D145FD5D-97FA-4069-B93C-1DF318747DD8.JPG
      Jan 2021
      Tennessee
      I believe those grooves are an indication that the yoke is dancing around in the tail housing because of your suspected drive shaft imbalance. How are you checking the pinion angle? Don't just point the rearend up the same angle the engine/trans is pointing down. Gotta compute both U-Joints "working angles" and get them the same. With that kind of wear, inspect those front U-Joint bearings and caps closely.
      Jacksonville, FL
      When you made the driveline angle changes, how did you measure them?. Use the TREMEC smartphone app to see what your driveline angles are. That is a good starting point. What engine mounts, trans and and suspension are you running? Are your wheels square (front to back wheels measurement the same)?
      Chris
      1968 Chevy Camaro SS
      LS3/T56 DSE suspension
      Jul 2008
      I'm dealing with a similar issue in my car.
      One thing a lot of people overlook is critical speed of their driveshaft.
      What tires and rear gear are you running? How long is your driveshaft, what's its diameter, and what is it made out of.
      I have 25" tall tires, running 3.73s, and my shaft is 3" diameter, .083" wall, 54.5" long. I've hit the critical speed of the shaft and now it's bent.
      *Jeff*
      Jan 2016
      Arizona
      I had someone else do the install, I just provided the parts.
      -Stock towers with 1” back ls swap plates
      -Bowler T56 with energy poly mount
      -Hotchkis TVS Suspension
      -yes wheels are square 18x9 with the same back spacing all around
      Jan 2016
      Arizona
      This is what I’ve been looking into as well. I have a 27” tall tire with 3:73’s. Driveshaft is 65” long and it’s 4” in diameter and it’s made out of steel.
      This is exactly what I was thinking it was.
      Jul 2008
      Is it 65" total length or 65" from center u-joint to center u-joint?
      I'd measured .020" runout in the middle of my driveshaft. Close to 60 you could feel it in the shifter, around 70 it felt like you had a DA stuck to your ass cheek.
      Check the chart below. The longer the shaft, the lower the critical speed. Think of a rope, when you spin it fast enough to turn into a jump rope, that's 1/2 critical speed. The point where you can spin the rope to make double U's, that's critical speed. That's exactly what your driveshaft is doing. At critical speed, that's when the shaft turns into a W, pretzels up, and spits out the tailshaft.
      https://pstds.com/critical-speed-chart
      *Jeff*
      Jul 2008
      Sorry for the double, figure out what your shaft's critical speed is, then, assuming your T56 has 1:1 4th gear, look at your rpm vs mph. That tells you what your driveshaft is spinning. My 1/2 critical speed was around 70mph, have my cutoff set to 140mph, driveshaft would spin 7000 rpm! Luckily I'd only gotten to 132, it was sketchy enough for me.
      You can use this calculator to look at rpm/mph/shiftpoints, I love it, helped me visualize my downshifts/upshifts:
      https://www.blocklayer.com/rpm-gear.aspx
      *Jeff*
      Jan 2016
      Arizona
      That’s from cap to cap 65”. Thank you that’s awesome. Mines the same, the shifter starts shaking at 70 then if I keep pushing it the WHOLE TRUCK SHAKES BAD.
      Jul 2008
      Jack the rear of your truck up, idle it in 2nd and watch the shaft, check to see if it's out of round. That's when I saw mine wasn't right and put a dial indicator on it.
      You might need a new tailshaft bushing in the trans too once you get everything sorted out.
      *Jeff*
      Apr 2007
      Greeley, CO
      It looks like the driveshaft might be too short. The wear on the yoke makes me think you don't have enough engagement on the tailshaft of the transmission and that is causing the driveshaft to flop around. You can tell by reinstalling the driveshaft with jack stands under the rear axle to simulate it sitting on the ground. Grab the yoke right at the u-joint and push up and down. If it is too short you will see and feel the movement of the yoke rocking on the tailshaft. I don't know how to explain it better than that. Maybe someone else has a better explanation.
      Matt H.
      Jan 2016
      Arizona
      Quote Originally Posted by 2yellow69 View Post
      I get what your talking about. The yoke has engagement where there’s only 1” sticking out, bowler recommends 3/4” so when I get my new driveshaft built tomorrow I’ll tell them. Hopefully they can just add 1/4” on to my old measurements. I think the driveshaft I have is past it’s critical rpm. It’s 65” long.
      Mar 2015
      Awesome thread. My fairly new (just hit 1000 miles) Chevy II wagon LS swap has a similar issue. Not as bad but definitely there.
      Apr 2007
      Greeley, CO
      Glad I made sense to you. I would also call the driveshaft shop before you go and ask them how they want the measurement. I have seen the way some driveshaft shops online ask for a measurement but the local shop I use wants it measured differently. They have me go from the end of the output shaft to the flat where the u-joint cap sits in on the rear yoke.
      Matt H.
      Jan 2016
      Arizona
      I took my driveshaft to a local shop here in town and explained my problem, and they checked it for balance and it was out of balance on the transmission side, the differential side and the center badly. They couldn’t even get all the way up to speed on it. So I have them building me a 4” aluminum driveshaft that’s just a tad longer to get a little more yoke engagement. It’ll be done tomorrow. Hope this ends this problem.
      He explained my driveshaft was over the recommended length for the steel, and with the horsepower in making, its pushing the limit of the aluminum. But he thinks if I keep my power where it’s at it’ll be just fine.
      Jul 2008
      Glad to hear you got validation on the shaft being bad. I got seriously lucky and found an 03 crown Vic shaft is 55.5" center to center, 3.5" aluminum. Just got one from the pull a part for $35, hopefully will be a bolt in for me once I swap the slip yoke. Mine's also stamped POLICE, internets saying that's the best version to get. Old shaft is 21.2lbs, Vic shaft is 15.6lbs.
      *Jeff*
      Jan 2016
      Arizona
      Thank you, that is a super awesome find, let me know how it works. I’ll check back on here this weekend to let you know if it’s completely gone or not.
      Jan 2016
      Arizona
      4” aluminum driveshaft with a sonnax yoke and 1350 u joints
      Hopefully this fixes most of it
      Jul 2008
      Quote Originally Posted by Cshenker1121 View Post
      Have you been able to run the new shaft?
      *Jeff*
      Jan 2016
      Arizona
      Yes all of the problems are now fixed!!!
