    Thread: 19" wheels
      Feb 2018
      London, Ontario Canada
      19" wheels
      Tried to order wheels today, 19x9.5 and 19x11. Offsets are +5 and +10. 69 Camaro mini tubbed I don't have my rear yet, going 9" after wheels are in place. Stock subframe. Is there any reason these won't work?
      Jun 2008
      It will rub when you turn. You might be able to make it work with the Ride Tech True turn.
      Jason
      Feb 2018
      Thanks for the reply Jason. I'm good with having to purchase different components if needed. Being that the rear has not been ordered a +5 offset shouldn't matter correct?
      I wouldn't order wheels until you have the rear in place and can measure clearance. Front depends a lot on the total setup. You need to measure fitment to some some baseline. Will be hard to fit a 9.5" on a +5mm offset, and I think the minimum tire for that size would be a 255/30. And unless you run a LOT of static camber and fix the camber gain, you'll rub on the fender. Most fit a 245 with the correct offset, improved camber gain, and aggressive street alignment.
      Suggest you do a lot of research on this forum and know your suspension setup, before you spend $$$ on wheels.
      Feb 2018
      See every other thread says get you wheels and tires first then measure for rear end
      Quote Originally Posted by Canadianwraith View Post
      Brainfart. Wasn't thinking custom-width specified narrowed rearend.
      Feb 2018
      Ya no worries, still great advice. I really want to get my car down on wheels
