      May 2021
      Texas
      1968 Protouring Camaro Twin Turbo LS
      For Sale as is 1968 Chevrolet Camaro
      Looking to sell my pro touring camaro I spent about 5 years restoring, this is not a show car, i taught myself a lot when building this vehicle. I am probably going to miss a few things in the list of stuff but pretty much nearly everything is brand new except for the inner skeleton. About 600 miles on the vehicle since the rebuild. The paint isnt perfect, some paint chips from driving on the highway, some panels arent lined up perfectly, this car i built for driving and not showing so it has many flaws including some rust. I have over $80k in it but asking $46,500.00.
      1968 Camaro, V8 vin, clean clear Texas title
      Brand new sheet metal all around, doors, roof, quarter panels, trunk lid, rear valance, rear spoiler, front fenders, 2 inch cowl hood, firewall, dash, upper dash, cowl assembly, floorpan, front bumper, DSE roll bar. Brand new windows, front and rear windshields, brand new window regulators, door panels, door handles, hinges, latches, locks, window knobs, Ring brothers door handles, Ron Francis Bare Bonz harness, new ignition and light switches, optima red top battery trunk mounted, Digi Tails LED tail lights, Custom Headlights, Custom front grille, 2nd gen mirrors, hidden neutral safety switch, Nitto tires,
      Suspension
      Stock front subframe
      Heidts subframe connectors
      DSE Quadralink rear suspension
      DSE front upper and lower control arms
      DSE front sway bar
      JRi coilovers front and rear
      Engine
      2002 Chevy Tahoe 5.3
      317 heads
      Drive by Cable
      Speed Density
      SBE
      ARP main and head studs
      Lil Johns Motorsports Twin Turbo cam kit
      Comp cams 1.72 gold roller rockers
      Holley front mid mount accessory kit
      LS6 intake
      FIC 650cc injectors
      Twin 51mm Turbos
      3 inch intercooler piping black powder coated
      Cx Racing intercooler
      Turbosmart Blowoff valve
      Turbosmart Wastegates 7psi springs
      Holley oil pan with turbo drains
      New T56 from American Powertrain with their swap kit for 68 camaros
      Quicktime bellhousing
      Hydraulic slave cylinder
      Wilwood hydraulic slave booster
      Custom aluminum driveshaft
      Moser 12 bolt 3.73 gears, narrowed with quadralink brackets welded from DSE, powdercoated black with DSE rear cover
      Rushforth wheels 18x8 front 18x10 rear
      Speed tech Spindles
      Wilwood master cylinder
      Wilwood front and rear slotted rotors, 6 piston front 4 piston rear
      Holley Terminator X Max ECU
      Holley Sniper Efi 91mm throttle body
      Gm 2.5 BAR MAP sensor
      MSD ignition wires
      Minitubbed
      Holley Frostbite radiator with dual electric fans
      PCV catch can
      Holley fuel pressure regulator
      Holley Sniper fuel tank with narrowed corners
      Earls EFI 3/8 Vapor Hose
      Holley inline fuel filter
      Holley 400 lph in tank fuel pump
      Dakota Digital gauges
      Flaming River Steering column
      Corbeau Seats
      Corbeau 4 point harnesses
      Driven Steering wheel from DSE
      JL audio C1 tweeters
      JL audio C2 cpeakers
      Pioneer Touchscreen deck
      New carpet, headliner, dynamat all over
Size:  284.9 KBName:  camaro2.jpg
Size:  303.1 KBName:  camaro1.jpg
Size:  263.5 KBName:  camaro4.jpg
Size:  389.0 KBName:  camaro8.jpg
Size:  474.4 KBName:  camaro7.jpg
Size:  436.8 KBName:  camaro6.jpg
Size:  309.0 KBName:  camaro9.jpg
Size:  400.8 KBName:  camaro11.jpg
Size:  142.5 KBName:  camaro13.jpg
Size:  203.9 KBName:  camaro15.jpg
Size:  160.1 KBName:  camaro16.jpg
Size:  161.8 KBName:  camaro17.jpg
Size:  470.0 KBName:  camaro18.jpg
Size:  287.4 KBName:  camaro20.jpg
Size:  257.8 KBName:  camaro19.jpg
Size:  310.0 KBName:  camaro10.jpg
Size:  275.5 KBName:  camaro22.jpg
Size:  181.0 KBName:  camaro25.jpg
Size:  343.1 KBName:  camaro24.jpg
Size:  369.4 KBName:  camaro26.jpg
Size:  134.8 KBName:  camaro27.jpg
Size:  276.2 KBName:  camaro29.jpg
Size:  331.8 KBName:  camaro23.jpg
      May 2021
      Texas
      Also needs exhaust from turbos back, I am located in East Texas.
      Dec 2019
      Interested. What’s your number?
      Jul 2021
      florida
      hey mate what is your number is this still for sale i will buy it!
      hey mate i would love to chat more about this ride, let me know or give me a text at 9497930103! thanks mate
      Quote Originally Posted by Dylnpgh8 View Post
      Suspension
      DSE front sway bar
      Engine
      317 heads
      Drive by Cable
      Speed Density
      SBE
      LS6 intake
      FIC 650cc injectors
      Twin 51mm Turbos
      Speed tech Spindles
      MSD ignition wires
      Minitubbed
      PCV catch can
      Corbeau Seats
