      Mar 2010
      Alabama
      Help---LS& in 69 camaro
      I have a 69 camaro that has the ridetech tru turn setup with a stock frame. I have a dry sump LS3 to install. I know that Speedtech has discontinued their dry sump oil pan. Any idea what will work as I want to keep the dry sump. Also, I have stainless work headers. Any idea if these will hit the tru turn?
      Thanks,
      David
      David Butler
      "If you're not first, you're last"
      67 Camaro Twin Turbo SBC (changing from Blow-thru to Holley HP EFI)
      Sep 2017
      I just went through this with an LS7.
      Only way your going to drysump this is ARE type flat pan and removal of your existing dual stage pressure / scavenge pump. You can install the ls style single stage pressure pump only and just run external scavenge but everyway you do it is 3500-4500.00
      For this reason I swapped to a mast motorsports pan and a LS3 pressure only pump and went back wet sump
      TANKMASTERJ
      Mar 2010
      Alabama
      I did pan modifications and changed the location of the inlet and outlet ports. Also notched the pan. It should work now.
      Jan 2014
      Portsmouth NH
      My combo is the Speedtech oil pan, dry sump LS3, ridetech Tru-turn and Hooker Blackheart headers. I can tell you that it is SUPER tight routing the lines to and from the Speedtech pan due to the Tru-turn. Clearance of the steering linkage is as tight as it gets. I made hard lines to give me the clearance I needed for the sump supply and return. Hope your modified pan gives you a bit more room.
      Cheers, Steve
