      Apr 2021
      LS3/TR6060 swap into a 68 Camaro
      Hi Guys,
      New poster here. I'm building a pro tour Camaro with an LS3/TR6060 swap going in. I picked up the whole setup with pedals and everything off a donor 2015 Camaro, whats the best way to setup the clutch for this type of swap. The donor clutch pedal doesn't seem like it would fit. Should be able to make the gas pedal work. Anyone make a conversion kit that makes this simple?
      Thanks!
      Oct 2011
      You need this kit from McLeod, come with everything including a new clutch pedal. You will use the slave cylinder that comes with the trans.
      https://www.summitracing.com/parts/mcl-1434002
      You will also need this fitting to connect the an line that comes in the kit to the clutch line at the trans.
      https://www.summitracing.com/parts/ear-652504erl
      You might as well pick up this bleeder as well. It will make bleeding the clutch much easier.
      https://www.summitracing.com/parts/hmi-tpsbl5g
      Apr 2021
      Quote Originally Posted by joeko23 View Post
      Thank you sir!
      I haven't watched the video series, but here is a video that may be helpful. It is part one of three about swapping in a TR6060 into a first gen.
      https://www.youtube.com/watch?v=d47sShq82XE
      Dave
      Oct 2011
      You’ll also need an adapter for the driveshaft, or just get a CV driveshaft from driveshaftshop.com
      https://www.sonnax.com/parts/3868-3-...er-flange-yoke
