    Results 1 to 16 of 16
      Jun 2018
      Alamo, CA USA
      Firewall holes closed up...
      I have to plug some holes in my '73 Camaro that aren't going to be used before I can get my engine back in there. I'm using a Vintage Air system and am being told the four holes in green can be closed up. Can you guys help me verify this? Is there anything else I should close up while getting this work done?
      Click image for larger version.
      Apr 2021
      Assume you are going to make a new hole for the Vintage Air bulkhead?
      Jun 2018
      Alamo, CA USA
      Quote Originally Posted by cheapdate88 View Post
      I thought the entire VA system runs through the big hole directly next to the passenger side front fender (not pictured here). No?
      You can close up all those holes if you are routing your hoses through the blower hole on the far passenger side.
      Jun 2018
      Alamo, CA USA
      Thanks, Don. Any other to include or are those the four to attack?
      You can likely fill the rest of those small holes unless you are planning to use the factory firewall insulation.
      Feb 2013
      The four holes on the passenger side are my Vintage Air pass throughs. The one below that is the bulkhead terminal for the trunk battery.
      Jun 2018
      Alamo, CA USA
      Well I'm planning to use insulation of some kind. whether it's factory or not, I'm not sure. There hasn't been much put on this car that's factory.
      Jun 2018
      Alamo, CA USA
      Is that where VA wants you to run their equipment? I always thought it was run through the larger circular hole closer to the fender.
      Feb 2013
      You can technically run them anywhere you want. Also keep in mind the firewall picture is my 69 Impala so the scale is somewhat different. My AC hoses run inside the fender and those holes are where they need to be for the lines to exit the fender and go through. If I ran through the large vent hole they'd cross out midway through the footwell.
      Unfortunately the car is apart at the paint shop right now and I can't show you how it looks assembled.
      The hole towards the middle, above the transmission tunnel is perfect for your EFI harness.
      Jun 2018
      Alamo, CA USA
      I was wondering about that. Thanks so much for bringing it up. The Terminator X Max is basically being placed right behind it on the firewall, yeah? For people who do block off that hole, where do they normally run the harness?
      That location is perfect for the harness. I just got these for my GTO:
      These are heat shrink harness passthroughs. I plan to use the large one for the harness. It fits a 2" hole.
      Or put an amphenol type detachable connector. Unscrew the engine harness at the connector, flip the wire harness over the engine, and yard that hombre out
      Greg Fast
      1970 Camaro RS Clone
      1984 el Camino
      Central Wisconsin
      Where are these from. I have never seen this style before.
      Tim Mc
      71 Cutlass
      66 Tempest
      65 cutlass
      15 BMW GSA
      Quote Originally Posted by TimMC View Post
      Made by TE Connectivity. Available from Waytek Wire and probably other sources.
