    Results 1 to 10 of 10
      Jun 2018
      Alamo, CA USA
      Fuel pump access panel...
      I'm getting ready to throw my Rick's Tanks Restomod tank into my '73 Camaro. As I was planning this out, I was thinking about how great it would be if I had quick access to the fuel pump after installation and how brilliant of idea I had of making some sort of access panel. A quick Google search revealed that my brilliance was short lived as I found several companies already making them.
      Do I just go with the Detroit Speed Fuel Pump Access Panel Kit? I feel like 9"x9" is kinda small, but maybe not? Someone else's kit I should be looking at? Is there anything else I should be taking into consideration for this?
      Thanks.
      Jacksonville, FL
Size:  224.1 KBName:  DF12CF24-970F-4EF5-8C79-97D6B46E022E.jpeg
Size:  180.8 KBHere is the DSE door going in my 68. I have a vaporworx tank also
      Chris
      1968 Chevy Camaro SS
      LS3/T56 DSE suspension
      I use the DSE on all of my builds. If you position it right there is adequate access for the fuel pump.
      Jun 2018
      Alamo, CA USA
      Sweet. It's been working for you? The 9x9 opening is enough room there to service what you'd like?
      Alright, well that answers that question then. I'll go grab the DSE kit.
      Oct 2011
      I thought the 9x9 was too small so I bought this one:
      Allstar Performance ALL18543 Access Panel Kit https://www.amazon.com/dp/B00YJEYB6W...R6QATXVV0X46P7
      It’s large enough that I can access everything from the trunk including sender and all wiring plus obviously get the pump in and out.
      If you look at my build, page 7 post 136 you can kinda see it but it’s covered by insulation.
      Jun 2018
      Alamo, CA USA
      17.5x17.5... wow, that's huge. I'm sure servicing anything under there is easy. My only worry is if it's too big? Am I compromising structure at that point? I'm guessing not, but I'd want to hear your thoughts anyway.
      Oct 2011
      It’s actually 10x14 the package dimensions are prolly 17x17. I don’t think your sacrificing anything structural. Your putting in a frame that will be screwed and seam sealed. I think it’ll be just as strong.
      https://www.summitracing.com/parts/aaf-all18543
      Jun 2018
      Alamo, CA USA
      Sounds good. Grabbing it now. Thanks!
      Sep 2016
      Bakersfield, CA
      That's a good find, that would even work well for servicing my 6x9 fuel module I bet.
      http://www.TheFOAT.com/92GTA
      1969 Pontiac Firebird
      Dec 2008
      Detroit
      I used the Allstar Performance setup in my car too. Easy install and i can get my pump and sender in an out with ease.....
      Big dreams, small pockets....
      Chris--
      '72 Cutlass S LSA/T56 Magnum
      Project Motor City Madness
