    Results 1 to 14 of 14
      Feb 2006
      Columbia Co. NY
      5 Point harness with stock seats?
      Just installed a Tigercage and Crow harness in my 67 Camaro. I have the harness installed as a 4 point right now. My seats are stock frames, re-foamed and covered TMI sport seats. Anyone know if I can set them up to work with the submarine belt? Is there a way to pass the belt through the seat properly?
      67' Camaro- 385 SBC/Autogear M22/Wilwood
      My 57' Truck build:
      https://www.pro-touring.com/threads/126935-Caddy-powered-pick-em-up-57-Chevy-truck
      Beach Park IL
      I am more concerned about the shoulder harness. Does this seat have headrests?
      No racing harness will function properly when installed in vehicles equipped with incompatible seats. Standard seats that have no headrests, or backrests with integrated headrests and no openings between the backrest and the headrest are non-starters. Most stock Porsche seats are like this, aptly named ‘tombstones’. In this type of seat the shoulder belts will simply slide off your shoulders during an accident, which isn’t ideal.
      http://www.speedhunters.com/2017/12/...ing-harnesses/
      Donny
      Feb 2006
      Columbia Co. NY
      I used seats out of a 69 so I could get head rests.
      Bollocks!!! I wish I knew about those special 4 point belts before I bought mine!!
      My 57' Truck build:
      Nice article! It covers all the recommended technical points from Schroth's own publications.
      First thing to notice: no mention of 5 point harnesses. They are a thing of the past -- you'll be wanting to look for a 6 point setup. And while it technically can be done with a stock seat, you'll be hard-pressed to find someone willing to take on the liability of modifying a stock seat.
      If you want a 6 point harness, you really ought to get seats that are rated for a 6 pt harness.
      John Parsons
      Feb 2006
      Columbia Co. NY
      I already have the 5 point setup and really like the Crow harness. Kinda seems like seats are in my future at some point though. They are more affordable than I had initially thought. I would need to find some that don't look super modern but have the modern features.
      My 57' Truck build:
      Feb 2015
      I was able to install these in my Nova for the tiger cage. Look under your seat to see if you can pass it through the seat frame. Only had to cut the seat foam out and did not have to modify the seat frame. Use a fabric pen to mark the top of the seat where you and it, then pass a screwdriver or something from the bottom to see if any of the seat frame will be in the way. Worked great on the Pro-Car Rally seats.
      https://www.sidebysidesports.com/blr...iABEgLyZvD_BwE
      Eze_1978 1968 Chevy Nova
      My build link:
      https://www.pro-touring.com/threads/...ova?highlight=
      Feb 2006
      Columbia Co. NY
      Quote Originally Posted by eze_1978 View Post
      Awesome!!!! This is exactly the info I was hoping to find. That turned out great, your interior is sweet. I will check out the bottom of my seats and see if there is room. Did you just bolt the submarine belt to the floor using a backing plate? Thanks!
      My 57' Truck build:
      Feb 2015
      When I bought my tiger cage the person who sold it to me had extra mounting plates for the tiger cage. I used the extra pinch weld bracket from the tiger cage then drilled a hole in the middle of the plate and made a backing plate out of 1/4 steel and secured it under the car.
      Here is the bracket I used. You could probably call and get one from ridetech or just use an I-hook and large washer. Here is the extra bracket that I used. Probably could just make your own if you wanted to.
      Here is another possible option.
      My build link:
      Feb 2006
      Columbia Co. NY
      more golden information from you sir! And the Gods must be smiling on me.. ridetech actually sent me 2 extra of those exact same plates you used. No idea why, but I will copy your setup if you donít mind!! Super excited to try out your solution. Thanks again!!!
      My 57' Truck build:
      Feb 2015
      Quote Originally Posted by rlovell383 View Post
      Donít mind at all. Glad I can help someone out. I know Iíve gotten some really good help on here to.
      My build link:
      Feb 2015
      Here is the install I found online that help me with my install. Good luck. Can always pm me with any questions.
      http://www.gtsparkplugs.com/cobra-se...sub-belts.html
      My build link:
      I used to be a Corbeau Distributor 10 years ago - I think I have a Box of these Plastic Belt Guards at home. I'll give a look this weekend
      BMR SUSPENSION
      T.C. Davis
      813-986-9302 Phone
      813-986-8055 Fax
      [email protected]
      www.BMRSuspension.com
      Like us on Facebook!
      Feb 2006
      Columbia Co. NY
      Quote Originally Posted by BMR Sales View Post
      that would be cool! Thank you!
      My 57' Truck build:
      haven't found them yet
      BMR SUSPENSION
      T.C. Davis
      813-986-9302 Phone
      813-986-8055 Fax
      [email protected]
