    Results 1 to 8 of 8
      Jun 2008
      Lafayette, Indiana
      Drive Line Angles on Lowered 1968 LeMans (A-Body)
      Hi All,
      I thought I would drop in from being a long time lurker to see if you all might be able to help me chase down a driveline angle issue on my lowered 1968 Lemans. The car was lowered all the way around with a Hotchkis lowering setup. If I recall correctly it was a two inch drop from stock. The rear end is an upgraded BOP ten bolt that was original to the car. I went ahead and put in adjustable upper control arms over the Winter and now am ready to try and sort out the vibration that the car is experiencing at 65 MPH +. It is indeed a drive line vibration as I tested that last year by nuetral dropping the trans at speed and the vibration remains until the car drops below 65ish.
      So here's where we stand.
      I've got an inch of clearance before the transmission is resting against the floor. So it could be shimmed up if needed. Using the Tremec app this morning I measured
      Engine / trans: 2.3 Degrees down
      Shaft was up 1.4
      Yolk was down 1.7
      I corrected to
      Trans still down 2.3
      Driveshaft settled to .7 up
      Yolk corrected to 2.3 up
      Car felt better at lower speed, but wants to shake itself apart at 70. The app showed an updated working angle of 1.7
      So what do I start moving to start correcting this? Do I start trying to shove the trans up which seems to be suggested by @AndrewB70 or can we make adjustments both places? I've done a lot of reading but just really confused about what adjustments to start making and where.
      Thanks all,
      Derek
      Raise the transmission. Listen to Andrew....
      May 2010
      kitchener,Ontario,Canada
      X2 Andrew knows his stuff
      Ryan Austin
      On twitter @raustinss
      On Instagram austinss70
      Jun 2008
      Lafayette, Indiana
      I agree Andrew knows his stuff. I've read many of his posts here and on Team Chevelle and other places relating to this issue. I just got in from the shop and have identified that in order to raise the transmission to get it to zero that I'm going to have to cut the floor to give the front yolk some room. Not ideal but doable. The flip side of that is that I've seen a number of people mention a CV Driveshaft from The Driveshaft being the ultimate solution. Again, the $1100 is not ideal but also doable and if it can be done without cutting the floor it would be nice. So now the question is what is the best option, I'd appreciate hearing from the first hand experience of this group.
      May 2010
      ok so let me ask you this , how do you feel about doing both ? you by the driveshaft and it doesnt solve it then guess you have to raise the tunnel . You raise the tunnel you can always add the shaft later ..yes ?
      Ryan Austin
      Jun 2008
      Lafayette, Indiana
      ok so let me ask you this , how do you feel about doing both ? you by the driveshaft and it doesn't solve it then guess you have to raise the tunnel . You raise the tunnel you can always add the shaft later ..yes ?
      Haha, honestly would prefer to do neither! I know that's not an option to get this really squared away. I was much younger when I made the decision to install the Hotchkis springs. I didn't realize the can of worms I was opening. Over the years the issue has been a minor annoyance. Since having the rear end rebuilt last year and really wanting to get the car dialed in so I / we can really enjoy it, this has become more of a priority. I may see if we can find a happy medium setup for the summer just so we can cruise around town and then tackle this over the Winter when I'm ok with the car being down for a few months.
      What comes to mind is just how much of the tunnel am I going to have to clearance in order to get the transmission to 0, or does the transmission even need to be level. Would getting it to 1 degree down be enough?
      Hopefully Andrew sees this and chimes in.
      I think whether or not raising the transmission works depends on your ride height. In a nutshell you don’t want a vee shaped driveline.
      CV driveshaft should fix it regardless of ride height.
      Quote Originally Posted by The Jury View Post
      I think my thoughts on the matter are pretty clear from the various posts where I have addressed the question. The solutions are, either raise the back of the trans or get a CV driveshaft. Raising the back of the trans can cause other issues, like accessories crashing into other components in the engine compartment.
      If there are more specific questions, I'd be happy to address them. Incidentally, I have the CV shaft out of my GTO and I can't use it now because I am moving the engine and also swapping my transmission. It MAY work for you, depending on engine and trans...
