    Results 1 to 20 of 27
      Martinez, CA
      Poly, Delrin vs Rubber bushing fitment
      I have a full Hotchkis suspension in my 66 Chevelle and would like to swap out all of the Delrin bushings for rubber. I want a smoother ride and am willing to sacrifice a smidge in the corners. This is daily driver on normal streets. I never track it.
      Iím trying to understand about the interference fit of bushings in the various parts, ie, control arms, frame mounts, etc. Iíve found a listing of bushing by dimensions but Iím not 100% sure how much interference I need to get them to stay put and operate correctly.
      Any help would be appreciated.
      1966 Chevelle, 3.6L/217 CI, 4 cam direct injected V6, 6 speed auto, full Hotchkis suspension, 4 wheel Wilwood discs, white w/red interior, cowl hood. 3260 lbs w/full tank. Built for 35 mpg. So far 32.
      Beach Park IL
      Factory rubber bushings are bonded to the inner and outer sleeves. The rubber then twists with suspension travel. I don't know how you can replicate that using existing sleeves if that is what you are proposing.
      If you are looking for an existing rubber bushing, with a sleeve already attached to press into your tubular(?) control arms I think you would be looking for .005" press fit.....maybe tighter.
      I think the problem you will run into is that most OE type bushings have a lot more rubber than an aftermarket bushing has Delrin. Consequently, rubber bushings will be larger by a significant amount.
      Donny
      Jul 2017
      Island Lake, IL
      Interference should vary by the bushing/material used. Isolation and articulation bushings have different requirements depending on use. In the pro-touring world, we’ve moved away from rubber body mounts to solid/poly/delrin. In leaf spring cars, for example, a lot of suppliers sell delrin/solid upper shackle bushings to keep the rear end location but use rubber on the spring eye to allow for more spring articulation.
      As you can see, this subject can be answered in various ways. Is there a specific part or bushing you’re looking/referring to?
      Martinez, CA
      I would really like to take some of the NVH out my car. I drive it everyday and itís just plain harsh. My thought was that if I changed the front and rear control arm bushings from Delrin to rubber it would make the ride a little more compliant.
      The body mounts are stock replacement rubber. I donít know the durometer.
      I have 380 lb springs in the front, 160-190 lb in the back. Rears have 1/2 coil cut so may be slightly stiffer. 2Ē dropped spindles, 0.9Ē taller upper ball joints and front/rear sway bars. I had 515 lb front springs and they were brutal.
      I like how it handles now but since I donít track it I donít think I will be giving up as much in handling as I would gain in comfort.
      I didnít think about the rubber bushing needing steel out sleeves. Except the rear uppers which have always been steel sleeved and itís the one bushing I can buy off the shelf.
      My front lower control arms take two bushing per ďlegĒ of the arm, pushed in from the ends. I donít remember if there was a steel sleeve in the center of the Delrin bushing but I would assume so. I thought if I could get a rubber bushing with the same dimensions and a steel center sleeve that it would be an easy swap.
      For the front uppers the bushing presses into the arm and onto the shaft. Iím not sure what the Hotchkis version looks like so that may take some homework.
      The front of the rear uppers and both ends of the rear lowers take 2-piece bushings installed on each side. Probably also have steel sleeves.
      Iím going to drop one of each piece off so I can take good dimensions of the bushings and the sleeves they fit in.
      I was hoping to just press rubber ones back in with an appropriate interference fit.
      Delrin move more smoothly and allow the control arm to follow it's rotational path more accurately than rubber bushings (rubber has stiction - more resistance, in addition to deflection). This transfers the loads to the springs and shocks better which actually improves the ride feel. So if you want a better ride than you have now, keep your delrin bushings and buy double-adjustable shocks.
      The added benefit, is if you were to ever track it, you could dial up the shock settings temporarily.
      Martinez, CA
      Quote Originally Posted by 68Formula View Post
      The suspension as it is now with Delrin bushings is jarring. Hitting a large crack in the road at 90 degrees jars the entire car. The ride is great, ie, smooth and flat through the corners, until I hit a defect in the road and my teeth loosen. My 67 with stock control arms with new rubber bushing did not exhibit this trait at all.
      I donít think my tires are super low profile and are the same as my 67 had. I just canít think of another way to try to minimize the jarring other than a softer durometer material in the suspension.
      Jan 2012
      Dallas, Texas
      The Delrin should provide a smoother movement through the range than a rubber bushing. I have Delrin in my car and the jarring feeling you describe is due to shock settings. If I firm up the compression and rebound the car can become harsh and non-compliant. Backing down those settings provides the smoother feel for daily driving. I have Viking Triples on my car with a UMI Performance Cornermax kit and could not be happier.
      Martinez, CA
      The shocks Iím running now are from Hotchkis as part of the complete kit. They are made for Hotchkis by Fox. They are not adjustable that I can tell.
      So talk me through shock selection....
      I canít overstress how much more important NVH is to me than the ultimate corner carver. I drive this everyday, rain or shine, to the grocery store or movies or ?? and am trying to make it smooth and quiet.
      The car is pretty light (3260 with full 20 gallon tank) with an aluminum V6 and Iím going to change the tires/wheels to save 6 lbs of unsprung weight per corner.
      Iím not opposed to adjustable shocks but once I find my comfort spot I would never adjust them. Probably worth it for initial tuning though.
      Michigan
      Rubber bushings do not have stiction - that would be impossible since they do not move inside their sleeves. As Donny said, the inner and other bushing sleeves are bonded to the rubber. The rubber portion of the bushing twists (think of it as a low rate torsion spring, with a little damping from the rubber) to allow the control arm to move up and down. Poly bushings, on the other hand, do have stiction, since the poly does move inside of its sleeves; that's why they sometimes squeak.
      The additional spring rate from the twisting of the rubber bushings is pretty negligible in my experience, especially if you tighten down the control arm bolts at ride height like you're supposed to.
      I'm confident that rubber bushings would help the OP's impact harshness issues, but it might not be worth it to make rubber bushings work in control arms designed for Delrin. Do you have an extra set of stock control arms you could rebuild with new rubber bushings? That would probably be the most cost effective solution.
      What others have said about shocks has merit as well. What are you running? KYB Gas-a-Justs can make a car feel like you're describing - they have a ton of compression damping and not much rebound, which is a bad match for stiffer than stock springs. Your rear spring rate sounds a little high too, especially for a lightweight car. The rear of your car has a bigger impact on ride quality since you sit closer to the back.
      All that to say, I think rubber bushings would help, but they may not be the silver bullet you're hoping for.
      - Ryan
      Michigan
      If you're concerned about NVH and do only street driving, rubber bushings are the best option for sure. Delrin has no "give" to it to take the edge off of sharp impacts.
      Those Hotchkis/Fox shocks should be right in the ballpark. I'm guessing they were tuned for a slightly heavier car, but they shouldn't be that far off. What tire pressure do you run?
      - Ryan
      Martinez, CA
      Quote Originally Posted by stab6902 View Post
      Iím running 36 psi cold all around. Fronts tires are 225/45-17 and rears are 275/40-18.
      The jarring is definitely from the front. Or at least WAY worse in the front. I even avoid Botts Dots.
      Itís not bottoming out as I have plenty of clearance to the bump stops.
      Michigan
      36 psi is high for the street in my opinion. I usually run 30 psi on the street - that was the standard for years until cars/tires were designed to optimize fuel economy (at the expense of everything else). I'd try 30 psi as a first step and see how you like it - it'll ride better for sure. With a light street driven car, you don't have to worry about the tires rolling onto the sidewalls.
      - Ryan
      Martinez, CA
      Iíll try 30 psi and see what itís like. The tires say something like 50 psi max so I though 36 was on the low side already.
      And I know the exact road to check it on today. I normally avoid it.
      Mountain Springs, Texas
      Lower tire pressure should make a big difference. Donít forget about unsprung weight. Are you running heavy cast wheels?
      The phenomena you are describing is commonly found in cars with lowered suspensions etc. I also attribute it to delrin bushings, and worse yet heim joints which I see on some setups. Shocks can make a difference imho.
      I also suspect that high spring preload combined with inadequate rebound damping can cause the harshness you described.
      If you take a look at DSE suspensions you will see they are running rubber bushings. So does Art Morrison. So do the OEM Corvette suspensions. Maybe they are onto something...
      Don
      1957 Buick Estate Wagon
      Martinez, CA
      Don
      My wheels/tires are pretty heavy at 47 lbs front/55 lbs rear. I mentioned earlier that Iím looking at new wheels which would drop these weights to 41/49 lbs per corner.
      The rear springs are 2Ē lowering with another 1/2 coiled removed but as I mentioned I feel the jarring is from the front.
      The front has stock height springs with 2Ē dropped spindles. I did reduce the front spring rate from 515 to 380 lbs/in. This is still up from the stock 290 lbs/in
      Iím also going to have to do more homework regarding shocks.
      Beach Park IL
      DSE uses delrin in all their front control arms and only uses rubber in the rear on their swivel links but Don's point stands and I agree.
      However, changing those bushings to rubber is not what I would call low hanging fruit nor do I think it will have a significant impact on your harshness issue.
      Tire pressure is a big deal and is free. I'd give it a shot. After that, I would revalve the shocks. Does Hotchkis send dyno sheets with their shocks?
      Donny
      Martinez, CA
      Tire pressure is a big deal and is free. I'd give it a shot. After that, I would revalve the shocks. Does Hotchkis send dyno sheets with their shocks?Ē
      I didnít get ďdunk sheetsĒ for the shocks. Itís actually the first time Iíve heard of one.
      Iíll call and ask them.
      wait...this isnít a trick to make ask Hotchkis a dumb question is it???
      Beach Park IL
      Dyno. I didn't edit my post, it says dyno sheet. It will look like this.
      Donny
      Nov 2016
      Sulphur, La
      Since the subject of shocks is up I'll add my .02. One of the first things I would want to do is to determine how much of my shock travel I am using in my typical driving. An easy way to do that is to smear some grease on the shock shaft and then drive around & see what got wiped away. If you have shocks apart I like to put tight o-rings on the shafts for markers. Then investigate where your bump stops come into play in normal driving. You need to verify that you are using your compression travel without slamming the bumps too hard in normal driving. Personally I feel that most of the harshness that people encounter is due to the rapid change of direction between compression to rebound. Slamming the bumpstops can cause this along with weak rebound. For my "soft" setups (on properly matched shock/springs) I run soft compression and a lot of rebound. It sounds like you may need softer high speed compression as I am assuming the the "cracks" in the concrete are not compressing your suspension much. I also find that if the car has very much bump steer that I perceive it as being rougher when I hit rough areas. Have you attempted to determine the frequencies front & rear?
      Martinez, CA
      I adjusted the tires down from 36 psi to 30 and it made a big difference! Not gone but WAY,WAY BETTER.
