    Results 1 to 18 of 18
      Jun 2018
      Alamo, CA USA
      Steering wheel recommendations...
      Could use some help choosing a steering wheel. Car will be daily driven with 8-12 competitive track days a year. I would say I have extensive road course track time, but nearly all of it has been in brand new production vehicles (I was in automotive media for nearly two decades) and drove whatever manufacturers made. Now that I can choose, I'm trying to identify what properties are most important to me. What are the factors I need to take into account? How do those factors affect me? What product or manufacturer recommendations could you make?
      Thanks!
      Edit: One of the recommendations given to me by the distributer I'm working with has been Billet Specialties. There's two that I'm eyeballing right now (Camber and Formula), but I was hoping to find something with the center alignment indicator strip on it as that's been objectively helpful on track days. Thoughts?
      Dont know your budget but right now there is probably no one better than Sparc Industries. Pick something from their line up or design your own.
      https://sparc.industries/collections...teering-wheels
      Greg
      Jun 2018
      Alamo, CA USA
      Quote Originally Posted by garickman View Post
      My budget is pretty open. It’s a part I’m going to be touching all the time, so I have no problem paying good money for a good product. I’ll check out Sparc right now.
      May 2018
      way east on a rock
      I'm a Momo guy- had this wheel in a few rides, when it gets knarly just replace it. Name:  dash.jpg
      Jun 2018
      Alamo, CA USA
      Quote Originally Posted by shelteredchevelle View Post
      MOD 69? That's exactly the shape I'm looking for. Did that fit directly onto your column or did you need to adapt it? I'm using an Ididit tilt steering column.
      Dec 2018
      I went with a wheel from Sparc and I am extremely happy with it. Jonathan, the owner also picks up his cell phone every single time I have called him. Which for me, is important.
      Oct 2007
      Camas, WA
      I am also going with a Sparc wheel. Jonathan is building a custom wheel for me right now that incorporates paddle shifters. Fantastic design and really strong.
      Jun 2018
      Alamo, CA USA
      Quote Originally Posted by Senek67RS View Post
      I looked into them. They seem a bit more boutique. A bit more flashy. A bit more form over substance. That's not really my style and not what I'm going for with this car. Looks like a great fit for the intended application. It's just not the application here. Thanks for the feedback and recommendation!
      Sep 2016
      Bakersfield, CA
      I just had Momo in Italy make me a custom wheel so I could get the design, material, center indicator, etc. exactly how I wanted. You can do it on their site. I have a similar wheel from a cheaper company that I use when daily driving it and bust out the Momo for track and shows. I have an NRG quick release so it's easy plus makes it much better getting in and out with the thigh bolsters on my seats.
      http://www.TheFOAT.com/92GTA
      1969 Pontiac Firebird
      Martinez, CA
      Con2R.com You can design and order a wheel online.
      Worlds Fastest LFX powered 1966 Chevelle, with a 3.6L/217 CI, 4 cam direct injected V6, 6 speed auto, full Hotchkis suspension, 4 wheel Wilwood discs, white w/red interior, cowl hood. 3260 lbs w/full tank.
      Jun 2018
      Alamo, CA USA
      I decided to go this route too. With the quick release, did that take the place of the adapter or is the quick release in addition to the adapter? I'd be worried I'm adding too much length to the column.
      Edit: Poking around shows me the quick release still needs to be connected to an adapter. I've got the Ididit hub on order right now, but I'm thinking it'll be better to grab NRG's short hub instead to keep the column length closer to factory. What hub did you use with your NRG quick release?
      Sep 2016
      Bakersfield, CA
      I have an Ididit Pro-Lite steering column. NRG and Ididit partnered on this setup and it's designed for the short hub adapter you mentioned, SRK-170H. I then used the SRK-280BK Gen 2.8 quick release, but whichever style you prefer should work. I also did the mod to remove the pin so it's one less step to remove and makes it much easier to do with your driving gloves on.
      I also hate logos so I removed the Pro-Lite sticker and the NRG logos. Looks super stealth.
      Jun 2018
      Alamo, CA USA
      I have the Ididit retrofit tilt column over the Pro-Lite, but looking at the lengths, all of those combinations should still work. And yeah, I'm with you on all of these logos. I remove them anywhere I can. Thanks for the feedback!
      Jun 2018
      Alamo, CA USA
      Alright. I have the Ididit Tilt Floor Column already. I'm partnering that with the NRG SRK-170H Short Hub and NRG SRK-200BK Quick Release. On top of this, I'll be using the MOMO Prototipo Heritage steering wheel. What I like about this setup is that it's going to give me a steering wheel position very close to the factory position, but I'll have the option to quickly switch to a different level and depth (eyeballing the MOMO MOD. 07 for that) when I'm doing track days. It's a flexible solution for me and I really like that.
      Thank you everyone for your input.
      Arizona
      Nardi Wheel
      I found a Nardi wheel on eBay that matched my interior..... Got the Ididit adapter and the wheel from the same vendor.
      Jun 2018
      Alamo, CA USA
      Quote Originally Posted by oleyeller View Post
      It's been hard for me to find pics of the Ididit adapter in black. Looks nice. Is that the factory column? The shape on that wheel looks real comfortable.
      May 2018
      way east on a rock
      Sorry for the slow response- I used Momo's adapter on the Ididit column. I did shave the collar a smidge to clear it from the column, but I didn't see a need for the NRG quick release hub.
      May 2007
      Las Vegas
