    Results 1 to 9 of 9
      Dec 2007
      arizona
      18 inch wheels for 500 or less each?
      I have been scouring the internet for weeks to try and find an 18 inch wheel with backspacing that will work for my car, i have seen a few with bmw bolt patterns, but to be honest I would prefer the proper 5x4.75 pattern. A little background on my car, it has 18x8 bmw wheels on it now with 5.25 bakspacing and they fit perfect. I know i could go wider in the rear most likely a 9 inch wide with 5.5 or 5.75 backspacing. does anyone know of any rims that would work for around 500.00 max per wheel? I really like the pro touring mesh style with 2 piece styling or a racing style with brushed centers.
      Rocket racing wheels:
      https://www.rocketracingwheels.com/t...es-wheels/c307
      1970 GTO Version 2.0
      Dec 2020
      Probable can find these for 6-650 a wheel but they are a 2 piece and your not gonna touch a 2 piece for $500. Was thinking these for my Chevelle but they donít make in 20ís and i want a 20Ē for the rear
      https://www.forgestar.com/wheels/mod...ed-series/m14/
      Dec 2007
      arizona
      Thanks, I saw the rocket attacks and thought those might be my only choice.
      - - - Updated - - -
      I really like the forgestars!
      Nov 2018
      This is what I'm using for mine, although I'm using a slightly different size. Summit Racing wants 218 each for VN5158961, which is this wheel for your specs in an 18x9 with a 5x4.75 pattern (5x120.65mm) and 5in backspacing. Plus it's a classic Camaro look. The main attraction for me was the 1700lb load limit (6800lbs total) for a wheel that weighs under 20lbs. Even fully loaded there's no way my truck will ever weigh in at 6800lbs.
      What I really wanted was slotted mags, but in an 18 inch wheel they're way over 40lbs each! With the Torq Thrust wheels, my wheel with tire won't weigh much more than just the slotted mags by themselves.
      Feb 2021
      Florida
      You can refer to the 4wheelonline passenger wheels section. Make sure you share a picture once you complete the installation of the new set of wheels. Vision, Konig, and ATX wheels are just a few of the brands you might consider for your ride.
      May 2018
      I ended up with the Rocket Attacks and LOVE them. They were the best wheel for the prize in the size I needed
      Jim..Car Junkie
      1969 Vette--Big pistons, No turbo....yet
      RX7 Turbo II--No pistons. Big turbo--now in my Daughter's garage
      68 RS Z/28, '12 Boss 302, 86 911, several RX7's, 3rd gen f-bodies, fox body, and many more..(gone)
      Southern California
      Another lesser cost option for a wheel in 2 piece welded:
      https://esajianwheel.com/collections...31780506828855
      And of course ET Wheels has decent pricing on cast center 2 piece wheels:
      http://www.etmags.com/lt_iii.html
      Dec 2007
      arizona
      Has anyone used these?Name:  18-ec7-5120-an-profile3_2_1.png
