    Page 6 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
    Results 101 to 120 of 140
    1. #101
      Sep 2009
      Glad to hear that you got the new snout installed and congrats on the kiddo! Curious how you are going to install the Hellcat pump. Do you plan to use a pwm pump?
      As for the pictures, I've used Flickr for years now. I just post the [IMG] code and it will show the pictures once I post. Not sure what you have been doing, but that's how I post them.
    2. #102
      Jul 2015
      KY
      I have looked at pwm and just staged. Not sure 100% on either one. Thanks itll be a life change but it is our third so got plenty of practice. Its just that he will be 10 years younger than our oldest. I have just been using the forum tools to insert images. Just does not seem to like these. They were HEIC and I saved as jpeg but no go. I will look into Flickr in a little bit. I have to map the rest of my outputs on the Terminator X. Need to make sure I have one for the pump and also got to check the input status as well I need to use one for the Flex fuel.
    3. #103
      Jul 2015
      KY
      So I tried to load to Flickr and apparently all the files are in .HEIC and it says invalid file and kicks them out as well. Guess I will have to get a converter program of some sorts or try to get my Synology to share the photos. Bummer. New baby came 8-12-22 so I will be home for the next week or so getting everyone back on track. Maybe Ill get time to address the photo issues.
      Hopefully soon I can get back to the car and get the new items installed. Also got a trans pressure transducer to install as well.
    4. #104
      Nov 2018
      New baby? We'll see you again in about 20 years. Congratulations on the new little one.
      2021 Durango R/T
      2005 Dakota beater
      2003 Dakota project-o-mobile
    5. #105
      Jul 2015
      KY
      Ha nope. Already done this twice. Last one was 7 years ago though. Got my budget all fixed up :-) . Heck he sleeps 2 hours at a time now so this week I will get a few things done while he is napping. Cause momma is napping at the same time as well.
      What do you guys think that the E85 will do to injector sizing? Is it add 30% for the extra fuel required? Or is there an easy formula for that?
      Apparently Apple defaults all pics to HEIC. So guess that is an issue from the latest SW update. Guess I will look for a solution for that as well this week.http://Way2qwk4u.quickconnect.to/mo/sharing/g9bGW0F6P
    6. #106
      Jul 2015
      KY
      Let see if this pic works. Getting baby on routine. Went out and worked in the garage last night between feedings and helping the wife.
      Ha looks like I got it figured out.
    7. #107
      Sep 2009
      Wow, that ported snout looks great! Who did the work? BTW, I can see the pictures.
    8. #108
      How does the throttle body seal with the o-ring gasket groove gone?
    9. #109
      Sep 2009
      That's what all the higher HP guys running LSA's do. They open the snout up to 102mm, then run a paper gasket.
    10. #110
      Wow, moving to a paper style especially with how thin the sealing surface is after removing all that material seems like it'd have issues. But if it works, it works.
    11. #111
      Quote Originally Posted by 68Formula View Post
      That gasket only sees engine vacuum, not boost.
      Instagram @projectgattago
      Dr. EFI
    12. #112
      Jul 2015
      KY
      DC porting took care of it. I made a mistake with the first snout. I thought that I was smart and pulled the old stock pulley off and thought I would just use my garage toaster oven to heat the new hub and slide it on. Well that kind of worked. It went on about 7/8 of the way to being flush. And then stopped. It was late and I was having a stressful day. So out came the persuading device. Its about a 8# one. And i got it almost all on the way and it was working. But I had damaged the bearings. So my fault I take full fault. Called DC porting and he had that snout already prepped and sent it out to me for a reasonable price and had it to me in less than 4 days. Awesome customer service. Sent him my old one and the spare hub I bought. Great company. Slapped the new snout on and was ready to rock.
    13. #113
      Jul 2015
      KY
      Correct as Andrew said it seals with a paper gasket. Its actually on my setup in order as follows.
      1. Throttle body
      2. Paper gasket
      3. Throttle cable bracket
      4. Paper gasket
      Has not seamed to be an issue.
    14. #114
      Jul 2015
      KY
      Here are some pics of the snout.
Size:  504.7 KBName:  IMG_5094.jpg
Size:  467.9 KBName:  IMG_5095.jpg
Size:  535.7 KBName:  IMG_5096.jpg
Size:  486.9 KBName:  IMG_5097.jpg
    15. #115
      Jan 2014
      Texas
      Wow awesome porting work!
      Also very glad to hear your family was all safe in that accident.
    16. #116
      Sep 2009
      That's a huge difference between the ported and non ported. What happens with the hard edge that's created now between the snout and supercharger case? I'd be tempted to pop the supercharger off and use the snout as a template to port the case.
    17. #117
      Jul 2015
      KY
      Yeah. Looked through the snout when it was installed. And like you would expect it has a good lip there. Im sure that causes a disturbance in the flow. Its on my list for a possible fall project. But honestly I think that after I finish tuning timing with Andrew and get the fuel situated I will be at the limits of a fairly reliable bottom end. Bottom end is all stock truck. Just hyper pistons and clevite bearings. Im really trying to decide on building a stroker from one of my many iron 4.8/5.3 blocks or just going bonkers and getting a 6 liter something or an LSX block. Then Id be more tempted to go full bore. I still have not gotten the nerve to got WOT on street yet. And I run outta fuel so there is that as well ;-)
    18. #118
      If the tune is right, and the rings properly gapped for boost, you should be good to at least 800whp.
    19. #119
      Jul 2015
      KY
      There are piston rings? What is gap? ;-)
      So I built the bottom end about 9 years ago for a friend. Never got paid and had to repo. So I know that I did not gap with the intention of boost.
      Does everyone have data for max rpm for the stock 2000 5.3 rod bolts?
    20. #120
      Jul 2015
      KY
      Updates to the project. Got some time over the Christmas break to work on the car and get a few things done.
      First most important thing got the new decor hung from xmas
      Got the car up on the lift ready for this winters surgery
      Old original worn out steering box removed. Unit was leaking and had about 3" of steering wheel play before anything was happening with the steering.
      New box on the bench. Fast Ratio Lares steering box.
      Painted and ready to replace the old box. Got the new box installed and can tell a big difference on the play in the wheel. Also much faster lock to lock.
      While I was up in the bumper area trying to find out why the horns don't work I found the noise from the front end I have been hearing the last few years. Apparently someone before me left a pair of vise grips in the bumper. :-)
      Dropped the tank and prepped it for the new fuel pump.
      New Walbro 450 hellcat pump installed and wired. Also going to install a fuel pump relay since the Term X is only rated for 30 and new pump can pull as high as 40 amps.
      Will update with more when I get it done. A bunch of little things to tidy up etc. Interior updates and wiring clean up. Still looking for a solution on a trunk finish kit. Not a good carpenter or fabric guy.
