    Page 3 of 3 FirstFirst 1 2 3
    Results 41 to 49 of 49
    1. #41
      Very nice job on the mini-tubs and the project overall. Fiberglass work is outstanding.
      1968 Camaro 6.2 w/ LSA, TR6060-Magnum hybrid, Z51 brakes, 12 bolt, Speedtech, Hotchkis, DSE
      1976 T/A LS1, 6 Speed, C5 front brakes, and etc. SOLD
    2. #42
      Jan 2021
      Tennessee
      Thanks! Your build is inspiring and giving me a lot of ideas as I consider powertrain upgrades. Hoping to pull that "LS" trigger this winter.
    3. #43
      Apr 2014
      Love the home built cars! Very nice fiberglass work!
      Good luck with the build!
      Pat
      - - - Updated - - -
      Pat
    4. #44
      Oct 2016
      The carbon fiber shims may cause corrosion. Make sure you have paint any where the metal (bolts) touch. I cant remember but I think stainless steel will have the lowest reaction. Project looks amazing. Love what you did with your dash pad.
    5. #45
      Jan 2021
      Tennessee
      Quote Originally Posted by Mike71nova View Post
      I had no idea that was a possibility and had to research it a bit. I'm in the aviation world and should have known this. Fail! LOL! Looks like as long the material is dried/cured before assembling/contact the galvanic corrosion possibility is minimal. The aluminum hinges are also coated and the bolts are stainless with no direct contact which helps.
      Thanks for the tip and forcing me to go learn new stuff.
      Cheers!
    6. #46
      Oct 2016
      Yes all we do is prime holes most of the time. Also Aviation here. Fiberglass layers also works wonders at stopping it.
    7. #47
      Jan 2021
      Tennessee
      Just some updated items and nothing major but some effective stuff and lessons learned. The older version of ridetech's 4-Link did start making noise especially after they warm up. Replaced them with the "R-Joints" and so far so go. Used the install jig to keep the lengths identical for my pinon angle during the swap.
      Saw a nicer looking front spoiler and gave it a try. I like the change and styling and the price was right at just a hundred bones.
      Needed some major changes with the exhaust. Was not able to run it over the rear-end but going under isn't as bad as I thought it was going to be. Even jacked with it hanging it does not touch the tubing due to the coil overs.
      Now for some fun tuning stuff for you carb guys. After some changes I could tell she was pig rich so on goes the AFR gauge to get her back.
      Tried as I may just could not get the stock metering block to play nice. Got an aftermarket block with adjustable restrictors for more fine tuning. Its said that with a bunch of patience you can get a carb close to EFI. Well, at least for the conditions on that day. LOL!
      For you EFI guys, this is what the software looks like for us old school carb guys.
      After two days of swapping jets, power valves, and restrictors, got the idle and WOT where it needs to be for my setup. Transitions to cruise (about 15:1) are butter smooth. Phew!!!
      As a reminder (and obviously I was a victim) if you see this nice thick carb gasket and think it'll seal well....RUN Away! Ended up over torqueing the carb hardware to get it to seal which results in this. I should know better. The result is an aftermarket billet carb base (that would be the purple barney one in the pic above):
      Lesson learned!
    8. #48
      Nov 2018
      I like that, carb software for the EFI guys. I also like how that overdrive transmission indicator looks like it was a 1969 factory piece. Very nice.
    9. #49
      Jan 2021
      Tennessee
      Thanks. I poke fun but truly getting gear together for EFI. One thing about that shift plate. I spent a whole day trying to cut/weld/modify the original shifter detent plate to get the shifter to line up with the correct indicated gear. Don't be cheap like me. Just buy the one for a 700R4 and be done with it. ;0)
