    Results 1 to 17 of 17
      Sep 2013
      Chicago suburbia
      1969 Charger Project Car - Viper TT motor, 6-spd, Art Morrison Frame, IRS, Wilwood...
      SOLD thank you to Mike Staveski from Time Machine Corvette who wound up finding me a buyer and getting me more than I had planned! Now, if I can keep him from talking me into a split-window coupe...
      Viper TT motor, 6-spd, Art Morrison Frame, IRS, Wilwood, etc.
      I am selling a deep dive project. This is not for the faint of heart, but if you have access to a shop and can do quality fabrication, this can be an award winning car. You hear the term “no expense spared” a lot, but just read on.
      1969 Charger with ‘68 grille, BMW halo headlamps, ‘68 style LED side lamps, ’69 Digitails sequential LED tail lights, Nu-Relic power windows, flush mounted front glass, hood design for reverse tilt and to cover the cowl completely (or could go factory). Ring Bros hood hinges. Lokar electronic door handles. Resto-Mod air. Original bumpers. Clear Illinois title. Body is in great shape. Looks like a 68 with 69 tail lights.
      Engine is a Gen III-IV-V Viper twin turbo custom built by Dan Lesser at Viper Specialty Performance. The block is a Gen III, heads Gen IV, and intake Gen V. Everything is controlled by a Pectel ECU with base tune used in the Viper platform. Engine data is displayed on a Cosworth Omega ICD full-color digital dash. No other gauges or indicators needed at all. Control includes 7-position full traction and launch control. Full engine harness is epoxy resin coated and MIL-spec connected. The turbos are CompTurbo ceramic coated 66/67 units. These are oil-less and maintenance free. Tial WG and BOV’s. Huge C&R air to water intercoolers with heat exchangers in the trunk. Headers and hot and cold side all custom built, purge and tig welded stainless and aluminum. All ARP and Vibrant hardware. This setup delivers 1500 HP with low boost, no lag. Fully bullet proof and street or track capable. The engine and associated hardware, dash, and ECU were $100k alone. I will post more detail and pics below.
      TR6060 6-speed with RPS triple carbon clutch, Quick Time bellhousing, and Strange driveshaft. Harmon fuel cell with in tank Walbro lift pump and low flow pump (base pump and WOT second pump).
      Frame is a full, custom spec’d Art Morrison frame with all Corvette underpinnings. Strange engineering independent rear suspension and Dana 60 pumpkin with 3.54 gears. Corvette C6 hubs, spindles, and control arms. Woodward power rack. Wilwood 14.25” brakes all around, 6-puck front, four pot rear, all spec-37 series. Currently on ZR-1 Cup rims and scrubs, but I have Mickey Thompsons S/R’s for all four corners. 30x12R18 in front and 31x18R20 for the rears. These tires are massive.
      Full roll cage. Tilt wheel. Recaro seats. Tilton pedal set. DBW throttle pedal. Painless chassis harness with LED blinkers.
      What you need:
      Most every expensive part is included, built, or installed. Material needed includes side and rear glass, door poppers, wheels for the M/T’s, small trim pieces. I have new tinted front glass for the flush mount. Fabrication needed: hood needs a bulge and extractor for radiator heat. You can extend this to the window as we planned, or go back to factory with some modification of the factory cowl. I have the original cowl vent panel. The firewall needs some finish work still. The trans tunnel needs to be finished. The roll cage needs the cross bar redone. One section behind the driver was removed to create a curved piece for more clearance. We later channeled the frame to drop the seat, however, so I would go back to a straight crossbar. Fuel cell needs to be installed (we have but were planning to modify). Hard fuel lines are mostly done, flex line needs finishing. All brake lines needed (have master, pedals, DBW throttle pedal, etc). Turbo coolant lines needed. Plumbing to fan needed (runs off PS pump). Piping through rockers for heat exchangers needed. ECU install and connect to existing engine harness. All chassis wiring including wiring to wheel Hall effect sensors (installed) for traction control, lights, and general chassis needs finishing (I have a Painless kit). Needs coilovers. Body and paint. Finish installation of everything. Dyno tune. Win some track events or shows.
      What I need:
      $140k. I am pretty firm on this price. Work on this full time for 6 months and you can have a half million dollar, SEMA level car. You don’t want to know how much I have into this project and it doesn’t affect the sale price anyway, but it’s many times that. I would consider a trade but it would have to be something as special as this.
      Bring on the questions and comments. More pics and detail to follow.
      Rendering by Murray Pfaff.
      '69 Charger TT Viper project - SOLD
      '65 Mustang Shelby clone project "almost done"
      Sep 2013
      Chicago suburbia
      More info on the engine:
      Viper V-10 Gen III block, Gen IV heads, Gen V intake up to 1500 HP (race gas) by. A proven package built by Viper Specialty Performance.
      -Blueprinted Engine w/ Oil System Modifications
      -Billet Main Caps & ARP Studding
      -Piston Cooling Oil Jets for Hot-Lapping
      -Custom Carrillo Billet Connecting Rods w/Multiphase Hardware
      -Custom CP Billet Pistons w/Coating Package
      -Heavy-Wall DLC Coated .990 Wrist Pins
      -Coated bearings
      -Keyed and Balanced Crankshaft
      -Gen-4 Race Oil Pan with swing-arm pickup
      -ATI Damper
      -Adjustable Timing Set & Custom Grind Camshaft
      -CNC machined Gen-4 Head Conversion Package w/dual Billet Throttle Bodies
      -Gen-4 Coil-Near-Plug Conversion, New Spark Plugs & Wires
      -RPS triple carbon clutch
      -Full Dual-Pumped Variable-Speed Weldon Based Fuel System
      -On-demand Secondary Fuel System Minimizes Hot Fuel Return, and is completely quiet during cruise
      -Polished and Anodized Billet Fuel Rails
      -Gen V intake
      -ID1000 Fuel Injectors
      -Pectel SQ6M12 Autosport Terminated Controller
      -Dual NTK Closed Loop Wideband Sensors
      -Dual EGT Monitoring
      -Dual Knock Detection
      -Cosworth Omega ICD Full Color Digital Dash
      -4-Calibration Selectable Tuning [91 Octane, 93 Octane, Pump/Race Mix and Race Fuel]
      -7-Position Selectable Traction/Launch Control
      -Internal System Logging
      -Full Engine System Warnings & Limp Modes
      -Expandable for Telemetry System Use
      -Full Powder-coating and Appearance Package
      -All ARP hardware
      Race prepped block, ceramic coated pistons with oil sprayers, etc.
      Custom built, epoxy resin coated harness.
      Pectel ECU, mil-spec connectors, and Omega full color digital dash.
      Near complete engine, turbos, and hardware.
      All these pics are current.
      Sep 2013
      Chicago suburbia
      Turbos, hot and cold:
      The headers are custom tig/purge welded SS units.
      Collector.
      Fitment.
      Taking a smoking break.
      The CompTurbo 66/67 units sit in the well behind the front wheel. These are oil-less, and can go in any orientation.
      Cold air intake goes up and over the front wheels in the fenders. The ungainly boxes are the filter, and would be completely hidden behind the bumper and valence.
      Compressed air goes through two huge C&R air-water intercoolers rated for this HP, to the custom throttle bodies. Water design is to plumb through the rocker panels to the reservoir, Bosch pumps, and heat exchangers in trunk.
      Huge C&R radiator. Fan is driven by original equipment Viper unit that is driven by the P/S pump and regulated by the ECU. This makes significantly more CFM than any electric pump can deliver.
      - - - Updated - - -
      Chassis:
      Full AME frame with Corvette C6 underpinnings. Woodward Rack. ZR1 hubs. Rear is a Dana 60 with 3.54 gears. The rear is a Strange engineering IRS designed off the modern Camaro. Wilwood brakes as described above.
      Here’s the frame as delivered.
      The IRS.
      Wilwood brakes.
      All fittings for suspension included. No coilovers.
      Brakes and ZR1 cup wheels. The calipers are currently in storage. The wheels and scrubs are just for rolling, you will need custom wheels for the M/T’s. You could use Corvette tires, but you’d need a completely custom offset.
      This is what the M/T’s would look like on mockup. Much better!
      The chassis was attached to the body using a custom built box spacer. The spacer was welded the full length between body and frame.
      Hard lines for fuel and return. This is as it is now.
      The setup is designed for a belly pan. Only the exhaust will hang below. This is a picture as it sits today.
      - - - Updated - - -
      Roll cage:
      The roll cage is fully integrated front to rear. The rear cross brace was modified from it’s original configuration and I would re-do it back to the original design with straight bars. The tubing to the rear chassis needs to be redone as it was removed to fabricate the rear bulkhead.
      Original design.
      The floor mounts for the seats were channeled giving the needed headroom, so the curved horizontal bar can go back to straight.
      The roll cage as it sits now.
      Sep 2013
      Chicago suburbia
      Interior:
      This was designed as a race interior. There is no dash, no interior finish, it’s all raw steel. Steering column, Omega digital dash, Recaro seats are included. You’ll need side and rear glass, a dash built, and some switches for power windows and A/C installed. I have the Resto-Mod air switches. Will need two switches or dials for fuel selection and traction control settings.
      Tilton pedal set and Lokar DBW throttle (older pics). The Resto-Mod Air box is on the right in second pic. The blower was changed to right angle for more clearance.
      Firewall and floor as it sits today. Needs minor finishing. Trans tunnel needs finishing.
      Maxi-tubs (old pic).
      Rear bulkhead. Fittings are for water to the heat exchangers.
      Water reservoir and pumps behind the bulkhead.
      Intercoolers in the trunk, one on each side. As it sits today.
      The project includes a Harmon fuel cell. However, the redesign of the trunk will require some reworking. Harmon is aware and will redo the tank; all the internals and fittings can be reused (you could do this yourself if desired). The tank now will sit behind the rear bulkhead. The fuel cell has in-tank primary and secondary lift pumps. The low pressure pump runs all the time and the secondary triggers on demand. All controlled through the ECU.
      Sep 2013
      Chicago suburbia
      Body:
      New quarters, left door. Fenders are in great shape.
      The grill was beautifully restored in flat black with BMW halo LED lights after media blasting. You will need an electric door actuator.
      The windshield was modified for flush mounting. The original frame edge was replaced with a custom made metal using a one off die. New front glass included.
      All lights LED, including button-style side lamps in new housings and Digitails sequential tail lamps. You'll have to click the link to see the video, they are gorgeous.
      https://imgur.com/SfI74Qk
      The hood has Ring Bros hinges. We partially modified the cowl vent panel and have been thinking of a reverse tilt hood. However, you could go either way. The original cowl panel could be used but would need to be modified. The current cowl panel is unfinished. The upper edge needs to be finished (glass would sit behind it as it is currently). The hood we had planned would sit on top of this panel.
      That's it. Sorry to hog the bandwidth. Let me hear your questions. I encourage anyone interested to come by and see it at the shop. We are in the Chicago suburbs.
      Aug 2015
      charlotte
      good lord this is insane...
      Pensacola, FL
      This needs to be finished....beyond impressive
      Sep 2013
      Chicago suburbia
      Thanks, guys. I think we all know this is one of a kind. Unfortunately, I cannot get it done. It's a lot of money, but it has so much more than the average build all ready to go. I hate to enter the market seeing so many people unloading nice projects.
      Oct 2016
      Impressive build ! Awesome !
      Feb 2019
      Wow what an awesome build!! I’m gonna get more lotto tickets!!
      1968 Cougar - 408, FiTech, AOD, TCI, Currie, RideTech, Wilwood
      1968 Skylark - 462, TKO 600, RideTech, CPP
      1985 Mustang - 04 Cobra/Terminator Swapped
      1988 Mustang - Vortech V3, Boss 327, Magnum, MaximumMotorsports, StopTech
      Sep 2019
      Country Flag: New Zealand
      Quote Originally Posted by slimjim View Post
      What he said. This is amazing. Just, WOW.
      When I die don't let Nina sell my car for what I told her it cost to build.
      Sep 2013
      Chicago suburbia
      This car is on eBay now. I hate to do it, but there it is.
      My Mustang is going into paint next week. I just want to drive a car when the winter is over.
      Sep 2009
      Wow!! Absolutely incredible. Good luck with the sale. As other's have said this car needs to be finished!
      EDIT: I found the link https://www.ebay.com/itm/1969-Dodge-...8AAOSw6GVgBnE7
      Sep 2013
      Chicago suburbia
      The car did not sell on eBay, and I will relist it tomorrow. Here's a punch list of work to be done and projected hours, not including body/glass/paint. This comes directly from the shop:
      Mount power steering cooler 2
      Power Steering Lines 4
      Turbocharger cooling lines 3
      Machine manifolds for rocker cooling lines 10
      Weld rocker cooling tubes to manifolds 3
      Install rocker cooling assemblies 4
      Fabricate doors and latches for air filter boxes 3
      Install probes in exhaust tubing from turbochargers 2
      Build exhaust, fabricate hangers 32
      Build sway bar mount and links, engineer arms 12
      Fabricate inner fender / splash aprons (engine bay) TBD
      Intercooler lines from rocker to intercoolers 4
      Fabricate oil cooler oil lines 1.5
      Fabricate oil cooler coolant lines 1.5
      Finish fuel lines engine to rear of car 5
      Design dash TBD
      Fabricate dash, TBD
      Design and fabricate firewall TBD
      Fabricate valance panel per rendering TBD
      Fabricate fresh air duct/scoops from valance to air box 6
      Fabricate Transmission Tunnel TBD
      Finish weld all interior panels and metal finish welds 16
      Design and fabricate trunk floor TBD
      Fuel cell mount 6-8
      Install fuel filler port in transition panel 4
      Fabricate tail panel per rendering 14
      Bumper modifications TBD
      Chassis wiring 56
      Computer wiring T&M
      Final assembly for chassis 12
      Final assembly for power train 12
      Bleed brakes 2
      Evacuate and fill intercooler system 2
      Evacuate and fill coolant system 2
      Misc 30
      Sep 2013
      Chicago suburbia
      Here is the eBay ad. I have lowered the price as well as the reserve. There are some updated pics. I'd love for someone from this site to buy it, I don't want this project to die on the vine.
      https://www.ebay.com/itm/1969-Dodge-...4AAOSw149gIKwT
      Sep 2013
      Chicago suburbia
      SOLD, thanks to everyone who inquired!
      May 2018
      way east on a rock
      I just hope it gets finished with the same quality and attention this build has had so far, it deserves it.
