Results 1 to 20 of 40
12-27-2005 #1
Ok engine masters. I need a little advise.
What do you all think of this package. It will run about 4500 shipped with my upgrades - They will upgrade this package to a forged crank, H-Beam rods and forged pistons for 600 bucks (I requested this for a turbo later on and the pistons will eventually need to be switched out).
I am thinking of going with these guys for my engine build. It is a used case, but they hand select each one. They dyno each engine, not just one and claim all the same.
The cam looks like this:
approx 224-232 at 050 and with a 1.6 rocker is right at 500 520 lift.
They build engines for NASCAR teams. I asked in another thread if anyone had heard of them and got one response:
T and L Engines
This is from their advertisement for a 383:
Included with your motor will be the dyno results of your engine.
The dyno chart in this listing is from our last 383 Stroker II, which dynoed at over 400HP and 460Ft-lbs of torque!
This engine is a new, powerful blue-printed engine, with all of its specifications
documented and filed at T&L Engine Development under its serial number.
It has been designed for pump gas use with 10.33:1 compression. It has been
professionally assembled by the same crew that builds the NASCAR race
engines seen on national television.
Yes, we are new to e-bay, but we are not new to the business. We have over
25 years of NASCAR race experience. Now, we are bringing this experience
and technology to the street. Add your name to our list of satisfied customers:
- Jarrett
- Labonte
- Nemechek
- Spencer
- Craven
- LePage
- Schrader
- Skinner
- Cope
- Fisher
and more...
In addition to a seasoned GM 4-bolt main block, we include the following:
New Rotating Assembly:
- 3.750" scat cast steel crankshaft
- 4340 6" scat I-beam forged steel rods
- Clevite 77 rod and main bearings
- Plasma moly Hastings piston rings
- Keith Black hyperuetectic pistons
New Parts:
- Dura-bond cam bearings
- Roller dual timing set
- Melling high pressure oil pump
- Steel sleeve oil pump drive rod
- Aluminum Dart Pro1 angle plug cyl. heads (2.08/1.60 valves, 215cc runners)
- Chrome dress kit
- Chrome oil pan
- Street series harmonic damper
- Cam bolt lock kit
- Gasket set
- ARP oil pump stud
- Oil filter adapter
- Silicone beaded intake gaskets
- Aluminum roller rockers (w/ 7/16 studs and 1.6 ratio)
- .080" wall chrome moly pushrods
- ARP cyl. head bolt kit
- Aluminum air gap design intake manifold
- T&L custom grind camshaft & hydraulic lifter set
- Melling oil pump pickup tube
- Spark plugs
- Oil and filter
- Brass expansion plug kit
- Valve cover hold down kit
Labor:
- All parts hand cleaned
- Block sonic checked for thickness
- Block pressure tested @40 psi
- Block stroker clearanced
- Block square decked w/BHJ fixturing
- Aligned hone mains
- Bored and honed w/torque plates
- All clearances checked to the nearest .0001"
- Rotating assembly internally balanced
- Engine blueprinted w/spec sheet on file
- Engine fully assembled and dressed to customer specifications
- Dyno tested
This engine is sold without the distributor, carburetor, wires, pulleys,and water pump,
although they are available at an additional cost.
If this engine does not suit your needs, or for written quotes on options
or custom engines, please call our facility located outside of
Charlotte, NC, the heartland of racing. Warranty options are available.
What cha think?
12-27-2005 #2Registered User- Join Date
- Nov 2004
- NW Arkansas
- 1,742
looks like a big time shop...never heard of them but what do I know???
looks like good parts are being used? Have you priced there warranty options?KENNY DAVIS HOTRODS
12-27-2005 #3No I have not done that yet, but I think I will. I believe I remember seeing somewhere on their site that they warranty through a 2nd company.
http://www.tandlengines.com/
LOL I had not heard of them either, but they sell themselves like they are big. If YOU havent heard of them, then maybe I should be worried. I generally dont trust eBay engine companies, but they 'seem' reputable. I hate being a guinea pig.
12-27-2005 #4Also, the used case kind of worries me, although their representative assured me they are hand picked for the best ones...from what pile, i am not sure.
12-27-2005 #5Registered User- Join Date
- Nov 2004
- NW Arkansas
- 1,742
I wonder what they would say if asked them for some contacts???? like there past customers? might be worth a shot. If that is there facility it is very nice, which is always a good thing
KENNY DAVIS HOTRODS
12-27-2005 #6Originally Posted by Travis B
12-27-2005 #7Originally Posted by Travis B
Charlotte is only 8-9 hours from here, so for me it would be worth a trip to see their facilities and maybe even pick up the engine to save on shipping costs. The list of internals seems pretty impressive.
Oh and it's a 'seasoned' block, not a 'used' block.... LOL
Dan
12-27-2005 #8Registered User- Join Date
- Nov 2004
- NW Arkansas
- 1,742
Originally Posted by Kuhlryde
some of those nascar guys are actually pretty cool...that is if you can get them on the phone. I was actually think maybe they had some cust other than nascar guys.......but maybe notKENNY DAVIS HOTRODS
12-27-2005 #9Originally Posted by Travis B
Originally Posted by dhardisonLast edited by Kuhlryde; 12-27-2005 at 11:35 AM.
12-27-2005 #10Banned- Join Date
- Aug 2003
- Orlando, FL
- 8,745
You want a honest answer, it is a horrible mis match. The heads are big and the cam is small. The 215s would be fine for a blower, nitrous or high RPM motor, but this thing will run out of wind with that cam long before you get to the sweet spot in those heads. I would much rather see 200 cc head, and a mid 230 / low 240s cam. This cam would still make plenty of vacum, and a small 3000RPM converter would make it a man. You want a beast, use those heads, cut them a tennie to get compression up to 10.8 or so, and bump the cam into the low 240s / high 240s. But now you are starting to thump a bit, but 500HP should be no problem. But honestly, I would still refer 200cc even then.
Also, I would not use Hyperexplosive pistons on anything except possibly a total stocker. The crank you could actually live with if you are not going to force it, the rods are actually pretty good, and those components do make for a nice light assembly. were as the forged h Beam stuff gets heavy
12-27-2005 #11Thanks Frank! This is what I was looking for. Would the cam be ok for a Turbo? He gave me those numbers when I emailed him asking about the forged crank for the future turbo.
NEVERMIND: I read that backwards
12-27-2005 #12
