    Page 2 of 4 FirstFirst 1 2 3 4 LastLast
    Results 21 to 40 of 61
    1. #21
      Chicago
      Nice work Frank.
      Very impressive fabrication skills.
      marty-mj
    2. #22
      Jul 2010
      south gate
      Nice work Frank.
      Thanks Marty
    3. #23
      Jul 2007
      nw phx
      Quote Originally Posted by BigBronco View Post
      What a snarky comment. .
      apologies for seeming snarky.
      Was just curious as actual usage from those who have used the digital dashes, if they are good for a daily driver.
      I have seen several in cars at car shows/SEMA etc. But have never been in one driving to know if there is any loss of view due to light.
      -Sorry to OP for the hijack, the dash you built is high quality, and if i owned the car, i'd buy one asap.
      ...life is too short, live for today, tomorrow isn't guaranteed
    4. #24
      Nov 2016
      I hear you that why I am gonna put a 69 Camaro dash in mine
    5. #25
      Jul 2010
      south gate
      Quote Originally Posted by Camarofreak67 View Post
      Got a few guys doing the same on they’re 2nd gens and firebirds
    6. #26
      Los Angeles
      Beautiful!
      Will that fit a 5th Gen ElCo or G-Body?
      1987 El Camino SS
      Displacement=357 CID 10-1
      Intake=Lingenfelter SR w/30 lb 52mm TB
      Heads=AFR 195 Street Eliminators
      Cam=Lingenfelter 219/219 .560/.560 112 LC
      Headers=Doug Thorley Tri-y 15/8", 2-1/2 exhaust
      Computer=1227730 NVSRAM S_AUJP_V4 Bin
      Trans=700-R4
      Rear End=GN 8.5 Posi 342
      Brakes= C-5
    7. #27
      Jul 2010
      south gate
      Quote Originally Posted by drb930 View Post
      Beautiful!
      This is specifically for 69 camaro and can be used on 1969 - 76 nova with minor mods
    8. #28
      Oct 2011
      SPRING HILL,FL
      Is it paint ready or will it need body work ? Thanks.
    9. #29
      Jul 2010
      south gate
      Quote Originally Posted by bill1969camaro View Post
      99% paint ready
    10. #30
      Jul 2010
      south gate
      Custom HolleyEfi 12.3 on 1969 camaro with 69 nova dash pad
      “ Little sneak peek at part #01-2021 for very special 1969 camaro ,
      YouTube clip https://youtu.be/l9ThXlYzmOc
      Will be making these below at $3k plus shipping running about 6 weeks out at the monent.
      pricey but each one is about 80 labor hours to produce .
      Brief description—————— custom aluminum 1969 camaro Holley Efi 12.3 gauge panel with 69 nova dash pad. These fit 69-76 novas with minor mods to car.
      These are custom made pieces using .063 3003 / 5052 AL . Composed of about 30 separate pieces that need to be precisely bent / shaped and Tig welded together without bleeding to inside corners for ultimate clean look . Will mount to stock locations and made for stock 3.5” steering column only and uses 69 camaro steering column lower collar. Very tight clearances for ultimate fit . Unit has overall curvature just like OEM , just very ergonomic in looks and function .
      Check out @1969camaroslunkworks for other awesome products for first gen protouring builds—
      #holleyefi #holleyefidash #holleyefi12.3 #grayareasteelco #rawsteelcamaro #zerowoodinterior #1969camaross #1969camaro #1967camaro #1968camaro #firstgen #camaro #firebird #holleyperformance #jlaudio #camarohoodlouvers #musclecar #customintake #1969camarohoodlouvers #chevroletperfomance #protouring
      #coldairintake #lscoldairintake #customkickpanels #jlmicrosub #firstgencamaros #kickpanelspeakers #kickpanels #customholleyefi
Size:  316.2 KBName:  IMG_1735.JPG
Size:  371.3 KBName:  IMG_1734.JPG
Size:  341.4 KBName:  IMG_1729.JPG
Size:  282.3 KBName:  IMG_1721.JPG
Size:  364.5 KBName:  IMG_1720.JPG
Size:  368.2 KBName:  IMG_1717.JPG
    11. #31
      Dec 2008
      Detroit
      I might have to get with you about the possibility of doing a bezel for my Cutlass dash... I modified mine and used ABS for now. Cutlass piece is much smaller
      Big dreams, small pockets....
      Chris--
      '72 Cutlass S LSA/T56 Magnum
      Bowler Performance, Rushforth Wheels, ATS, Holley EFI, KORE3, Ridetech
      Project Motor City Madness
    12. #32
      Jul 2010
      south gate
      Quote Originally Posted by csouth View Post
      Thank you but for the moment I’m just doing this set up. Wish I could help
    13. #33
      Jul 2015
      South Bay Area, CA
      Great work. Do you know if it will work in a 69 camaro with the Ididit tilt column??
    14. #34
      Jul 2010
      south gate
      Quote Originally Posted by Just_a_69 View Post
      Yes it will work but will have a 3/4” gap around your steering column , I would check with I did it I believe they have a sleeve for stock dimensions
    15. #35
      Jul 2010
      south gate
      Still working my way down the list ,
      1969 camaro custom Holley efi 12.3 cluster $3k
      Kickpanels $750
      Kickpanel speaker buckets $750
      JLMICROSUB subwoofer enclosure $350
      https://youtu.be/Rz0Q6LVP13E
      https://youtu.be/siq-0iowOz4
      https://youtu.be/LISbzmNA_SQ
      ATTACH]184405[/ATTACH]Name:  IMG_1831.JPG
Size:  334.7 KBName:  IMG_1981.JPG
Size:  480.1 KBName:  IMG_1982.JPG
Size:  427.9 KBName:  IMG_1983.JPG
Size:  498.4 KBName:  IMG_1819.JPG
Size:  343.0 KBName:  IMG_1822.JPG
Size:  332.3 KBName:  IMG_1834.JPG
Size:  419.9 KBName:  IMG_1833.JPG
Size:  413.5 KBName:  IMG_1720.JPG
    16. #36
      Sep 2017
      As impressed with Frank's fab skills on my hood heat extractors as I am all these photos just solidify it more. Excellent work frank.
      Anyone out there needing his skills you will absolutely not. E disappointed.
      Jason
      TANKMASTERJ
      Jasons Toys
      2000 HD Softail
    17. #37
      Jul 2010
      south gate
      Thank you Jason , i give it all I got , both on product an service 🤝
    18. #38
      Feb 2021
      Looks awsome bro
    19. #39
      Apr 2021
      What were the minor modifications that had to be made for this to fit in the 70 Nova?
    20. #40
      Jul 2010
      south gate
      Quote Originally Posted by kasprzykdc06 View Post
      Will need to extend steering column 3/8 threaded hangers and drill a hole that will be hidden to attach panel
