    Page 4 of 6 FirstFirst 1 2 3 4 5 6 LastLast
    Results 61 to 80 of 120
    1. #61
      Jan 2016
      Alabama
      It is not intended for racing, but just to give some added strength and safety to old sheetmetal that has been sliced both ways and welded. I also put some side impact bars inside the doors.
      Thanks, Vimes, for expressing concern.
    2. #62
      Jan 2016
      Alabama
      A few years ago at pull-a-part I came across an aluminum bumper from an Audi. Someone had removed the bumper cover, etc, and the bumper was just laying on the ground begging for a project. I snatched it up, and have now adapted it to the jailbar. It will be behind the grille, but should provide some safety and protection.
    3. #63
      Nov 2018
      Quote Originally Posted by charliebob View Post
      Heh heh, actually was saying I like it, because it didn't require crawling into a mass of tubing to get in. Asking about legality was just me being curious if something like that was meeting any organization's racing regs. That bumper looks good on there too.
      2021 Durango R/T
      2005 Dakota beater
      2003 Dakota project-o-mobile
    4. #64
      Sep 2021
      Very unique build. Can you tell us more about the 3UZ engine choice? Is the crown vic front suspension used for it's compactness, lightness, both, or something else?
    5. #65
      Jan 2016
      Alabama
      Quote Originally Posted by ProTouringMan View Post
      My 3UZ is a JDM, but in the US they come in Lexus LS430 and GS430. Mine is a 6 speed, with paddle shifter.
      Obviously I don't have any brand loyalty--my loyalty is for good parts that are cheap--but the Jailbar keeps begging for a Coyote engine. About 5,000 reasons have kept me from keeping it Ford. Dollars that is!
      Putting a Toyota engine in an old Ford is blasphemy to many; to me it is a just a super reliable, light, all aluminum engine with 300+ hp. And Toyota V8 engines are now made right here in Alabama!
      The 03-10 Crown Vic front suspension is very popular for swaps into F100s. Compact, light, good geometry, independent, rack & pinion steering, and fairly big disc brakes all in one neat package. It is too wide for the older trucks, but fits my widened jailbar.
    6. #66
      Jan 2016
      Alabama
      Sprayed epoxy primer on cab and doors so I don't have to worry about rust. Frame is up next.
    7. #67
      It looks good all one color!
    8. #68
      Jan 2016
      Alabama
      U-POL Raptor bed liner as an undercoating
    9. #69
      Jan 2011
      Jefferson City, MO
      I've debated how to weatherproof my Lark's underside when I build it. This seems like a good solution.
    10. #70
      Jan 2016
      Alabama
      Quote Originally Posted by Peanut1959 View Post
      Raptor liner is really easy to use, and has held up very well in my El Camino bed.
      I will also apply it to the undersides of fenders to cut down on noise and to keep rocks from chipping paint on the topside.
      Seam sealer can be applied under the Raptor liner.
      Like those Larks!
    11. #71
      I like the raptor liner , wish I had used it on mine. Nice job.
    12. #72
      Jan 2016
      Alabama
      Took a break from sheetmetal bashing and painting to make a relay and fuse panel fitted underneath the passenger seat, with an aluminum protective cover. The black box is a 1980-90s chevy truck underhood fuse box, rewired. Wiring for engine is separate.
    13. #73
      It looks great nice and neat.
    14. #74
      Sep 2013
      sw Kansas
      Looks good.
    15. #75
      Jan 2016
      Alabama
      Thanks guys
    16. #76
      Jan 2016
      Alabama
      To get adjustability in ride height and spring rate, I converted the CV front shocks/struts to coilovers using aftermarket sleeves (had the parts leftover from a earlier project). The upper CV mount has a round flange that fits inside the CV spring but will not fit the 2.5" ID coil spring. So the CV flange was removed and replaced with a flange that fits outside the 2.5" ID spring.
      A new flange on the upper mount is the only metal fabrication required. Bushings are all stock CV.
Size:  411.7 KBName:  IMG_6606.jpg
Size:  405.7 KBName:  IMG_6608.jpg
    17. #77
      Jan 2016
      Alabama
      Fuel tank mounted.
    18. #78
      Mountain Springs, Texas
      Awesome build.
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
    19. #79
      Jan 2016
      Alabama
      Awesome build.
      Don
      Thanks, Don. Lots of work left to do.
    20. #80
      Sep 2017
      Progress was paused on sheetmetal bashing so that I could build a frame. To keep things simple with readily available parts, I used a Crown Vic front suspension and a 9" Ford rear with triangulated 4-link. I'm using coil overs on the rear, with overload air bags (not in pic) in case I want to haul heavy loads.
      Front and rear frame stubs will be added later. The driveshaft hoop looks clunky, but made strong because this is where frame twisting forces are centered. An additional hoop will be added toward the front of the driveshaft.
      Now I can mount the cab and get back to sheetmetal work.
      The crown vic front goods look like it was factory dreamed up to go there. Awesome work. I'm digging the wide old ford and subscribed.
      Tankmasterj
      TANKMASTERJ
      Jasons Toys
      2000 HD Softail
