11-20-2020 #1Registered User
- May 2008
- 10
FS: 1970 Plymouth Barracuda Grand Coupe project w/ Speedkore Carbon Fiber Clip + more
1970 Barracuda Grand Coupe Project with complete SPEEDKORE Carbon Fiber Front clip/bumpers & Ring Brothers Billet hood hinges – pin kit.
Not looking for an entire project? The Speedkore Parts available separately
https://www.pro-touring.com/threads/...27#post1349627
The Car: Original FK5 deep burnt orange metallic paint over burnt orange interior, 318 A/C car with its original paint.... so no hidden issues under old body work ( you can see the exact condition of the metal).
The Good
-Matching numbers body (shell, cowl, radiator support).
-Clear Colorado title in my name ( no salvage or rebuild)
-Complete Car (minus drive line & suspension).
-Original A/C car with correct dash
-All glass/actuators included
-Near mint hood
-Complete burnt orange interior (w/ bucket seats, grand coupe overhead consule & A/C dash)
-Complete stainless trim including grand coupe badges
-AMD door skins and hinges have been installed
-AMD front inner fenders & aftermarket supports have been installed.
The Bad
-Lower portion of the rear quarters and outer wheel wells need replacing ( new AMD metal included).
-Small area of rust on driver floor board, does not effect subframe.
-Rear trunk pan / trunk pan extensions will need replacing
-Small area of rust on passenger-rear frame rail, can be repaired w/o replacement.
-Windshield will need replacing
Condition: VERY SOLID main floor/rockers/frame Rails. No rust on the roof (vinyl top removed in the 80's). No rot around the windows or cowl. Doors have been re-skinned with AMD metal.
*******car is mounted on US CAR TOOL 8" ball bearing casters for easy trailer loading. I can source/install a basic suspension for any international buyers.
SPEEDKORE CARBON FIBER PARTS
COMPLETE SPEEDKORE PERFORMANCE 1970 CUDA FRONT CLIP. This entire front clip including engine bay panels, bumpers, side marker housings currently sells for over $28k with shipping & sales tax. ( Pay for the kit and get a free donor car!)
THESE ARE NOT CHEAP PARTS MADE IN CHINA!!! ALL PRE-PREG HAND LAID AD AUTOCLAVED IN GRAFTON WISONSIN...CARBON WEAVE LINES UP ACROSS ALL PANELS.
The same parts that were used in the construction of The Cuda' known as “Menace” owned by Kevin Heart. Unless otherwise indicated, All panels have been clear coated for protection and are still wrapped in the original bubble wrap. No test fits or installations. The full carbon kit includes...
- complete hood w/ inserts. ( clear on the top, primed on the lower). has not been drilled for pins.
- RIGHT & LEFT fender assemblies w/ headlight buckets & inner supports - (fenders have been primed black up to the hood line).
- front hood header panel & supports
- front bumper w/ mounting brackets
- Lower Valence Panel
- Rear Bumper w/ mounting brackets
- set of 4 side marker light housings
- Engine bay insert -smooth fire wall, R & L inner fenders, radiator cover ( not even listed on their website)
Shipping is available w/in an 8 hour drive of Denver.
$22,500 for everything. $15,000 for the Speedkore parts alone. I will NOT sell the car separately unless the Speedkore parts sell first.
11-20-2020 #2Registered User- Join Date
- May 2008
- 10
SpeedKore pre-preg Carbon fiber clip/parts
Every part they make plus the engine bay inserts not found on the website.
12-30-2020 #3Where are you located?
01-21-2021 #4Registered User- Join Date
- May 2008
- 10
01-21-2021 #5Registered User- Join Date
- May 2008
- 10
Price drop...$22,500 for everything. MUST pick up.
03-30-2021 #6Registered User- Join Date
- May 2008
- 10
Sold.....................
