    Results 1 to 11 of 11
      Jun 2015
      Country Flag: New Zealand
      265 35 18 295 35 18
      anyone running these sizes on a 68 camaro?
      Jun 2015
      or 305 35 18 on the rear?
      Are you running a stock subframe? And are you mini-tubing the rear?
      I'm curious on people's responses as I haven't heard anyone running that size on the front without an aftermarket subframe, or limiting turning radius and/or modifying the inner fenders. On the rear the largest I've heard without tubbing are 285s.
      Jun 2015
      tubbed rear and trueturn sub
      Jun 2015
      bump
      Nov 2009
      Ca
      I ran 255's and 295's. OEM subframe and tubs in rear. Im currently notching the subframe to fit 275's and goin to 315's in the rear
      Jun 2015
      any pics?
      - - - Updated - - -
      Quote Originally Posted by paint2361 View Post
      any pictures?
      Feb 2018
      Southern IN
      Before I mini tubbed mine, I ran 275/40-17 drag radials in the back and 245/40-17ís in the front with a stock subframe. After updating the car with mini tubs, LS, T56 and full DSE suspension front and rear, I run 315/30-18 in the back and 275/35-18 in the front. I donít have rubbing issues or limited turn radius but in order to eliminate rubbing on the front during autocross events, I had to switch to Anvil carbon inner fenders. For normal street driving, there wasnít much of an issue but under hard cornering/braking, it rubbed like crazy. Hereís some pics, before and after.
      Shane
      #theanchorholds
      68 Camaro build thread:
      http://lateral-g.net/forums/showthread.php?t=56387
      Jun 2015
      Quote Originally Posted by Gmachine1911 View Post
      Before I mini tubbed mine, I ran 275/40-17 drag radials in the back and 245/40-17’s in the front with a stock subframe. After updating the car with mini tubs, LS, T56 and full DSE suspension front and rear, I run 315/30-18 in the back and 275/35-18 in the front. I don’t have rubbing issues or limited turn radius but in order to eliminate rubbing on the front during autocross events, I had to switch to Anvil carbon inner fenders. For normal street driving, there wasn’t much of an issue but under hard cornering/braking, it rubbed like crazy. Here’s some pics, before and after.
      nice ,good looking car
      Jun 2015
      bump
      Jun 2015
      bump
