    Sep 2020
    MA
    Largest width 18" wheels and tire 2nd generation F body with Full Ridetech coil over
    I am trying to make a decision to mini tub or not to mini tub. I am leaning toward not but wanted to see if anyone running the ridetech coilover package front and rear has any real world experience for the largest width 18" wheels and tires including back spacing for 2nd Gen Camaro/Firebirds. Any input is appreciated.
    1979 Firebird with a 1970 front end, T tops!, built 71 400 est 450 HP, TH400, 10 bolt posi 4.10's
    Beach Park IL
    My 71 Camaro 18x9.5 6" backspace with a pretty aggressive front alignment of 2.5* negative camber. The front rubs a little bit everywhere which tells me it's perfect. I run 265 or 275 35/18
    Same in the rear, you would need approximately a 1/4" spacer, I widened my axle to runs square wheels and tires.
    But you have a Firebird. Should be able to run 10" wheels without too much trouble.
    Donny
    Jun 2016
    Upstate NY
    79 TA. I run an 18x10 Budniks on the rear of mine (8.5" on the front), 5-3/4" (rear) backspacing. 295 tire. Not tubbed, DSE drop leafs, stock rear axle. When the 295s are gone, I'm going up to try a 300 series.
    Sep 2020
    MA
    Thanks for the replies. That's a fat tire!
