    Page 1 of 6 1 2 3 4 5 6 LastLast
    Results 1 to 20 of 110
      Jan 2013
      ST George UT
      1969 Camaro Full DSE RHS LSX 427 twin turbo, best of the best
      I am offering up my 1969 Camaro Best of the best. When I say "no money spared", i mean it, not CPP or ridetech parts.
      With that out of the way here we go. The list is long so hang in there.
      1969 Camaro, clean CA title in my name.
      -Car was taken down to metal.
      -Rear spoiler was molded in and laid back.
      -Rear bumper was hand built and pocket into the car.
      -Side marker light shaved.
      -Kindig-it door handles installed.
      -Drip rails shaved.
      -All factory body spot welds and normal imperfections smoothed.
      -Firewall smoothed.
      -Smoothed dash speaker grill.
      -Body had been primed and blocked 6 times for show car finish.
      -DSE mini tubs.
      Every part of the car has been mocked up before body work and car was running and driving, then pulled apart for paint. Many hours in to this build.
      Now for the good stuff.
      Engine & transmission:
      -RHS LSX 427 all aluminum block.
      -Callies dragon slayer crank.
      -Callie Ultra rods.
      -Wiseco custom billet forged turbo pistons.
      -Mast motorsports heads built by LME to match.
      -Titanium instake valves.
      -Inconel Exhaust valves.
      -8 pac racing valve springs.
      -Rpm racing rocker arms with Smith brothers grunion kit.
      -Smith Brothers push rods.
      -ARP stud kit.
      -GP tuning turbo cam.
      -Billet timing chain.
      -LME billet intake with dual injectors and dual electric throttle bodies.
      -LME billet valve covers.
      -Nelson 88 mm twin turbo.
      -Blow off valve.
      -Dome pressure sensors.
      -60 m waste gates.
      -Magnum T56
      -Bullet proof scatter shield.
      -McLeod Daul disc clutch kit.
      -Billet flywheel.
      -McLeod Clutch master cylinder.
      -McLeod Clutch throw out bearing.
      -Holley Dominator EFI module
      -Holley dual injector driver module.
      -Holley traction control module.
      -Concept-One front pulls set up.
      -Stainless work turbo headers.
      -Custom 3" Stainless mandrel bent tightly welded exhaust all the way out the back.
      Front suspension:
      -DSE Hydroformed sub frame, powder coated and complete with coil over and rack and pinion steering, spline sway bar.
      Rear suspension:
      -DSE quadra link with dual adjustable coil overs.
      -DSE sway bar.
      -DSE rear tow hooks.
      -Mosser 12 narrowed 12 bolt.
      Brakes:
      -Baer 6 piston front
      -Baer 6 piston rear bakes with E-brake.
      -Baer re master black master cylinder.
      -Hot Rod shop Hydro boost kit.
      -Hand built stainless steel lines.
      Fuel:
      -Ricks custom stainless tank, custom 3 Walbro 450 pumps camaro style module assembly.
      -Stainless steel hand built lines.
      Extra:
      -DSE mini tubs
      -DSE exhaust trunk clearance.
      -DSE trunk fuel door.
      -DSE floor spring pocket braces.
      -DSE weld in sub frame connectors.
      -Bowler raised transmission tunnel.
      -Ring Brothers Billet hood hinges Air frame (Also bought black ones) you pick
      -Ring Brothers billet trunk hinges. (Also bought black ones) you pick
      -Ring Brothers billet door strikers. (Also bought black ones) you pick
      -Ring brother black hood adjusters
      -Billet black door sill plates
      -Ring brother black billet door vents
      -Custom Billet trunk latch.
      -Eddie Motor sports billet tail lights.
      -Sequential LED tail lights.
      -American Auto wire car wire harness.
      -NuRelic power windows.
      -Ididit tilt steering column.
      -Rain Gear hidden wiper kit.
      -Vintage a/c kit.
      -Vintage a/c 3 knob controller.
      -New black stock dash gauge bezel.
      -Budnik billet steering wheel.
      -R/S front grill.
      -American heart beat electric r/s headlight door conversion.
      -Anvil carbon wiper cowl panel with vent delete.
      -AutoRad complete aluminum radiator support with aluminum radiator, inner coolers.
      -DSE radiator close out panel.
      -Marquez Hand built front bumper.
      -Forgeline wheels 19X12 rear 18X9 front
      -Michelin Pilot sport tire.
      -Clayton billet pedal assembly.
      -Clayton drive by wire pedal assembly.
      -Fesler front and rear flush mount glass kit. All body work done to fit the glass.
      -New smoked side glass kit.
      -All modules and coils are mounted inside the car on custom brackets.
      -New factory deluxe door panels.
      -Dakota Digital HDX gauges.
      -E-Stop Electric E-brake.
      -LLC Shop rear package tray wrapped in black leather.
      -LLC shop speaker box for DSE car.
      -Billet trunk mounted battery bracket.
      -Optima battery.
      -American auto wire battery shut off and remote jumper leads.
      -New factory dash grab handle and trim
      -Black or polished or stock Billet R/S headlight door covers.
      -New felts, seals, gaskets
      -New door latch's
      -Power trunk kit
      -Billet ride billet left and right outer mirrors.
      -Billet ride black billet inside rearview mirror.
      Much more i am forgetting.
      Car will be painted show quality upside down inside out.
      Car will be re assembled, running gear installed and running and driving.
      What will need to be done:::
      Interior of your choice.
      Install side glass and power windows.
      Wire in headlights and taillights.
      Engine and gauges, battery, a/c all wired in and in working order.
      Car will be painted next week.
      Jan 2013
      ST George UT
      Ok
      Underside is all sealed up and painted tin table bed liner. Went with metallic gray. Firewall this week then take off rotisserie and paint entire car. Name:  IMG_3140.jpg
Size:  88.0 KBName:  IMG_3148.jpg
Size:  168.0 KBName:  IMG_3147.jpg
      Aug 2019
      Painted yet?
      Jun 2010
      Deployed
      Very nice selection of parts...I agree it’s funny when people say no expense spared and I see parts that are from from top of the line.
      1970 Camaro/DSE build
      Jan 2013
      ST George UT
      "Is car painted yet?"
      I am very very picky, i had body shop block and prime car a couple more times and fix any factory imperfections inside door jams, hood jams and so on. I just sighed off on color and body lines yesterday, they will start to paint the car next week. It is going Gunmetal Grey effect, black z28 stripes
      Jan 2013
      ST George UT
Size:  276.5 KBName:  IMG_3253.JPG
Size:  94.2 KBName:  IMG_3252.JPG
      Body should get painted next week.
      Aug 2019
      Looks great!
      Jan 2013
      ST George UT
      Thank you. Cant wait to see it painted and rolling again. Went down to body shop and installed all the suspension and brakes.
      .Attachment 182303Attachment 182304Attachment 182305Attachment 182306
      Apr 2010
      North Jersey
      Looking good! Anymore update pics!? Beautiful car with a lot of nice parts. I’d trade my two for this one. Lol
      1967 Camaro SS 350 Hotchkis TVS, 383/TKO600, dynatech/magnaflow. #’s matching 350 stored
      1997 Camaro SS 6spd, Custom AI cam with all boltons
      2011 GMC SIERRA 2500 lifted w20’s (Driveway Statue)
      2009 Tahoe (Work truck) 220,000 and still going
      Jan 2013
      ST George UT
      Thank you.
      I will try and get some this week.
      I have been out of town. I asked the body shop to hang the door and wet sand and polish the car then I am going to pick up the body and get it running again and install all the parts.
      Then I will take back for them to hang the front clip sheet metal. I will post in my build thread. Just another 69 twin turbo camaro...
      I posted my build for sale while it was at the body shop and we all know how body shops can stall and even kill a bad ass build. Well that is what happened.
      So the owner of the body shop and i sat down and I explained that I want the car done and a #9.5 or higher and if I have to pay more to get that done in a timely matter I will.
      That worked for the next 2-3 weeks when I stoped by there was 3 guys working on my 69 and now she is painted.
      Looked great when I seen it last week. Those pictures were straight out of the booth no wet sand and polished yet.
      I have a couple guys still calling everyday and wanting to purchase the car.
      I might sell it or I have a 66 nova and 61 impala.
      Oct 2020
      69 camaro
      is car for sale still
      Jan 2013
      ST George UT
      I shouldn't because i could never buy or do this kind of build again but I would consider it.
      Cool ride, love that color, what is the paint color/manufacturer? Looks over the top.
      Mike
      86 Buick GN, Stage 2 V6, Twin EFR Turbos
      Jun 2015
      Alabama
      Quote Originally Posted by classiccarcustoms View Post
      Can u message me price and/or contact info ?
      Jan 2013
      ST George UT
      Thank you.
      PPG
      Straight out of the gun.
      No wet sand and polish yet.
      Attachment 183294Attachment 183295Attachment 183296Attachment 183297Name:  IMG_3993.JPG
Size:  395.6 KBName:  IMG_3997.JPG
Size:  377.0 KBName:  IMG_3998.JPG
      Jan 2013
      ST George UT
      Dec 2019
      Price?
      Jan 2013
      ST George UT
      I posted my 69 while it was in paint jail and I was very frustrated. Since it was painted I removed the price and asked ad to be removed. $185k the way it is.
      Car is running, all new side glass is installed, power locks and windows installed.
      Fesler dash installed, billet ac vents, power trunk, Digital tail sequential led boards, Eddie motor sports billet tail lights.
      All seals, felts and rubbers installed.
      Lokar billet shifter and ball.
      Billet push button headlight switch and module added as well as bush button wiper switch and module.
      Billet e brake push button, traction control and trunk buttons as well.
      Matching billet switch for power windows in the console.
      Everything is wired in and working.
      Jan 2013
      ST George UT
      Come get it before interior....
      $185k.
      I will have all the body panels aligned and installed before it leaves.
      Everything is tested and in working order.
      Aug 2017
      California
      What’s the PPg color code? This color is amazing!
