      Jul 2017
      Highland, IL
      Wilwood Remote Master Cylinder HELP
      I'm running the Wilwood compact remote master cylinders, which have a 3/8" - 24 outlet on them. Wanting to minimize the number of fittings, while at the same time running as much hardline as possible. The issue is that these MCs require a banjo bolt, and I can't find a banjo fitting that allows a hardline with a 45 degree double flare. Anyone make such a thing?
      Mike
      69 Javelin
      6.0 LS
      Tremec T-56
      DSE X-Gen & Quadralink
      Nov 2014
      East Tennessee
      I am not sure. My suggestion would be to get a 3/8 Banjo to -4AN fitting. from there adapters exist to go from -4 to 3/16" and 1/4" double flare. Alternatively, you could run hardline with -3 and -4 fittings on them and forget the double flare stuff.
      Electrical/Mechanical Engineer
      1968 Camaro RS - Flat Black
      Jul 2017
      Highland, IL
      Quote Originally Posted by Sleeper68 View Post
      Thanks. In the meantime, we decided to run 37 single flare (stainless), and found the fittings for that to work.
      Mike
      69 Javelin
      6.0 LS
      Tremec T-56
      Why not use a regular 3/8x24 45 degree brake fitting and bend the line as needed?
      Jul 2017
      Highland, IL
      We couldn't get the stainless steel line to double flare very well. Talked to a couple guys who said they've had good results using a single flare 37 degree to an AN fitting when using stainless.
      Mike
      69 Javelin
      6.0 LS
      Tremec T-56
