      Nov 2019
      1971 Camaro Rs Protouring
      1971 Camaro RS Protouring.
      SUPERCHARGED LS2/SIX SPEED
      BODY Original Texas Rust Free Car Retains all original metal Body off restoration done Media blasting of all components including body All sprayed in high zinc epoxy primer Paint Porsche Artic Silver with custom carbon fiber stripes detailed with red pin stripe, all high end materials used Glasurit paint and clear coat All new components throughout,
      New brake lines,
      Griffin aluminum rad
      Flexalite twin electric fans
      MOTOR (Brand New) All aluminum LS2 with LS9 cam upgrade
      Magnacharger TVS 1900 supercharger
      Katech front mount heat exchanger
      Fast 65lb fuel injectors
      92mm billet throttle body
      BRP custom conversion motor mounts TRANNY
      T56 six speed with LS7 clutch
      BRP custom conversion tranny cross member with mount
      FUEL SYSTEM Holley intank with custom baffle system, inline filter regulator, braided line with an fittings front to back
      REAR END Currie powder coated Ford 9" with big bearing torino bearing ends 389 gear with Strange nodular center section
      RIMS TIRES Asanti / Fesler 19" 3pc rims 305 30 19 Hankook V12 rear 255 35 19 Hankook V12 front
      BRAKES Dual diaphragm booster Wildwood adjustable proportional valve C6 Z06 front 14" rotor 6 piston caliper C6 Z06 rear 13 1⁄2" rotor 4 piston caliper with drum in hat E brake Kore 3 rear ford 9" brackets Lokar ebrake cables Kore 3 hubs with GM tall sprindle brackets Up graded 1⁄2 20 wheel studs
      EXHAUST BRP ceramic coated mid length headers, 3" stainless steel exhaust with tail pipes
      SUSPENSION STEERING Trans AM quick ratio steering box QAI front adjustable coilovers DSE 3" drop rear leafs CAL TRAC (Traction Bar) Gen 2 frame connectors
      GAUGES Autometer phantom II AEM wide band air fuel Carbon fibre gauge bezel
      MISC Howell EFI computer and harness ( motor & tranny) American autowire (complete kit) Fat mat insulator New carpet and interior panel kit Recaro interior Custom wrapped dash Custom wrapped console LED headlights Custom bumpers front and rear (buttons removed , fang added to rear, chrome stripped and painted body color) Trunk mount battery Lokar throttle cable Car Made 550 RWHP and 540 FT with a mild tune at 7lbs of boostThanks for your time
      Need help attaching video !!
      car is located in Toronto Canada area
      Price $ 89,000 Price is in USD
      Jun 2010
      Deployed
      Is it finished? I'm assuming its a stock frame/leaf spring car? More pics? Engine bay? Interior?
      1970 Camaro/DSE build
      Jun 2010
      Deployed
      Is this how it sits? Unfinished?
      Nov 2019
      post video
      can someone help me post video?
      Feb 2013
      Beautiful build! Good luck with the sale!
      Ridetech Suspsension
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
      Nov 2019
      Thanks! someone will get a great car
      Nov 2019
      Btt
      Quote Originally Posted by SPEEDSTREAM71 View Post
