      Sep 2020
      Los Angeles, CA
      1970 Chevy C10 Pro Touring Build - No Limit frame
      Body
      -Clean title with current CA tags
      -Frame that came with the truck was not original and was twisted/parallelogram
      -Original bed was in very poor condition, no bed included with sale
      -Cab was put on a rotisserie and has been sandblasted and epoxy primed
      -New inner and outer rockers
      -New cab corners
      -New smooth cowl panel (fiberglass)
      -New custom firewall inserts
      -Floors are solid with no rust
      -Drip rails shaved
      -Cargo lamp shaved
      -New doors, hood, fenders, radiator support
      -Stainless hardware kit for front end
      -Porterbuilt hood hinges mounted on firewall
      -Energy suspension cab bushing kit and new hardware
      -New windshield
      -New flush fit back glass kit
      -New Precision weatherstrips for doors
      -Ididit tilt steering column
      -Original bench seat in decent shape
      -High hump transmission cover by Slosh Tubz
      Frame/Rolling Chassis
      -No Limit C10 Pro-Tech Chassis (*high kick rails in the rear--bed floor will need to be raised)
      -Setup for LSX family of engines
      -Can mount a variety of transmissions
      -Fuel tank with high flow pump capable of 800 rwhp
      -Dual 3/8" fuel lines
      -9" Floater rear end with Eaton True Track 3.30 gear ratio, Moser Axles
      -Front and Rear Splined Sway Bars
      -14" Wilwood 6 piston calipers, rotors and pads, 5 x 4.75 hubs
      -14" Wilwood single piston rear caliper with integrated parking brake
      -Frame has been powdercoated "Black-Magic"
      -4 Link "Fat Bar" with heim rod ends
      -Battery box with drop out battery tray (mounts in rear of frame)
      -Flaming River road race rack & pinion steering rack
      -Frame is set to accommodate up to 10-11" wide wheel up front, 12" in rear
      -Total from No Limit for the above parts was $22,000, took 6 months to build
      Currently has a 6.0 LQ4 with an Isky cam, springs, etc for boost, 4L80E with a Jake's 2800 billet stall converter and HD2 shift kit. Also have a KB Racing turbocharger kit with a Borgwarner S475 Turbo and 1000 hp Treadstone intercooler. I also have an Entropy LS Swap radiator/fan setup, Holley Dominator ECM plus wiring harnesses and sensors, new 80 lb injectors, LS6 manifold and throttle body, Holley front engine accessory kit. Goal was to make 700-750rwhp. Receipts and invoices all available.
      $37,950 for everything
      Located in Chatsworth, CA
      [email protected]
      1970 C10, No Limit frame, LQ4/4L80E/Borg Warner S475
      2004 Pontiac GTO
      2014 Cadillac CTS-V
      Sep 2020
      Los Angeles, CA
      Price dropped to $34,750. I'm likely going to start selling off drivetrain parts separately, including the turbo kit.
      2004 Pontiac GTO
      2014 Cadillac CTS-V
      Sep 2020
      Los Angeles, CA
      Bump
      2004 Pontiac GTO
      2014 Cadillac CTS-V
      Sep 2020
      Los Angeles, CA
      Price lowered to $37,950 for the truck and everything I have to go with it.
      2004 Pontiac GTO
      2014 Cadillac CTS-V
      Sep 2020
      Los Angeles, CA
      Truck sold!
      2004 Pontiac GTO
      2014 Cadillac CTS-V
