    Page 2 of 2 FirstFirst 1 2
    Results 21 to 40 of 40
    1. #21
      FWIW I've been running the 295/40/18 Falkens on the back of my 71 Firebird for over a decade and love the 40-series in the rear. I'll be changing the front 255/45/18 to a 255/40/18 soon when I replace the tires.
      SMSgt Ty Ingle, USAF
      "CF71" - Freedom Bird
    2. #22
      Feb 2019
      Not much Summer tire selection in the 295/40-18 size. For a matching front and rear set it looks like Nitto NT555 G2 is my only choice. I really like the Falken Azenis FK510, but they don’t have a 295/40-18. How would y’all feel about mixing the Azenis FK510 front with the stickier Azenis RT615K+ for the rear? This car will be driven only on nice sunny weekends. Cruising and some spirited driving when up in the hills.
      1968 Cougar - 408, FiTech, AOD, TCI, Currie, RideTech, Wilwood
      1968 Skylark - 462, TKO 600, RideTech, CPP
      1985 Mustang - 04 Cobra/Terminator Swapped
      1988 Mustang - Vortech V3, Boss 327, Magnum, MaximumMotorsports, StopTech
    3. #23
      What's wrong with the 615s with 295/40 and 255/40 front?
    4. #24
      Feb 2019
      Quote Originally Posted by OLDFLM View Post
      What size rim do you have up front?
    5. #25
      Feb 2019
      Wouldn't a 245/45 be better on the 8” rim? I was thinking 255/40 might be too wide on the 8”. Also, this would be the first time I’m considering these softer 200 tread wear tires. I’m guessing these don’t last long.
    6. #26
      My fronts are 18x8 and the 255 fits that rim width perfectly imo! 18x10s out back fwiw
    7. #27
      Apr 2008
      Virginia Beach VA
      A 255/45/18 is OK on an 18x8 rim but not a 255/40/18. You can check any tire brand on Tire rack or other tire sites and see:
      255/45/18 = 8" - 9.5" rim
      255/40/18 = 8.5" - 10" rim
      -Joe
      Joe Lincoln
      Lime Green 71 Olds 442 Convertible
      Upgrades thread: https://www.pro-touring.com/showthre...ible&highlight=
    8. #28
      Quote Originally Posted by 71OLDS View Post
      -Joe
      I may have use the 255/45. It's been a while. Check heights. You want the front to be about an inch less diameter than rear.
    9. #29
      Apr 2008
      Virginia Beach VA
      A few other options with the 295/40/18 and 245/45/18 combo:
      1. Nitto 555G2s front and rear. I good reliable tire - not real sticky but gets the job done and is safe in the rain.
      2. Nitto NT05s rear Nitto 555G2s front. There's your 200TW tire rear - stickier - don't get crazy in the rain - same as above for front.
      3. Nitto NT05s rear and Michelin Pilot 4S front. same as #2 for the rear - much higher end tire on the front - incredible for corners and for both wet and dry traction. It's expensive but I'm running this tire on the front of my 442 now and love it. I have Nitto drag radials for even more grip for launching but like to combine with the MP4S on the front to make things a little safer overall when I get caught in the rain.
      Joe Lincoln
    10. #30
      Feb 2019
      -Joe
      This is trip. I just saw what you were saying in TireRack. You would think the opposite lol!
    11. #31
      Feb 2019
      So no weird issues mixing front and rear tire compounds right? 300TW front/200TW rear? My nephew has the FK510’s on his BMW. I really like them. Also, I’m leaning more towards a Falken set so I can rotate them side to side. If I can fit 255/45-18 front that would be great. Hopefully I can get away with just removing that center screw in the fender. I will not be driving this car in the rain. Only on nice days
    12. #32
      Apr 2008
      Virginia Beach VA
      Nah - no issues mixing TW ratings. I've got 100TW rear and 300TW fronts right now and the car drives great. You certainly can run the 255/45/18s on the 18x8 but it's just such a tall tire and for all the reasons I mentioned on post #10 here, I would still suggest the 245/45/18. If you decided to go with the 255/45s, just make sure your BS is perfect if turning radius (making U turns etc) is important for you. Also I believe your front and rear will be almost the exact diameter - or maybe only .1" taller in the rear.
      Joe Lincoln
    13. #33
      Sep 2013
      Houston, TX
      Here's another good tire combo with excellent wet & dry traction:
      Continental Extreme Contact Sport tires 340 AA
      Front: 18x8 4.5"BS with 26.7" tall 245/45ZR18
      Rear: 18x9 5.25"BS with 27" tall 285/40ZR18
      Rodney Meyers
      72 Olds 442 Rest-mod clone
    14. #34
      Feb 2019
      Just got em back from the tire shop. These 295/40’s are thicker in person than I was thinking. Do RT615’s run bigger than other brands? A 45 series would definitely be way too tall. Should fill up my rear fenders much nicer
    15. #35
      Quote Originally Posted by STREETFIGHTER50 View Post
      They definitely run wider than the Nitto 555s in a 295/45
    16. #36
      Jul 2011
      Peoria, AZ
      Any pics of them mounted on the car?
    17. #37
      Feb 2019
      Oops I forgot to post these pics up. The 18x10” 5.97” BS with 295/40-18 Falken RT615 tuck in nicely. Really centered in the wheel tub. I had to adjust the exhaust just a little bit.
      Before with the 18x9” 275/40
      Size comparison between the 275/40 Toyo Proxes T1 vs. 295/40 Falken Azeni 615+
    18. #38
      Apr 2017
      TN
      Looks great!
    19. #39
      Feb 2007
      Tinley Park, IL
      Nailed it!
      Nick ~
      1969 Cutlass
    20. #40
      Feb 2019
      Thanks for all the info y’all! I really do like these a lot more than the previous set
