      Oct 2007
      Nu-relic giant hole for S boots? Better way
      Looking at the install directions for my nu-relics. Its suggesting i drill a 7/8" hole in my body and doors.. I am like that a huge hole.. I dunno if I like that for two 12 gauge wires....
      Does anyone have a better option for running two 12 gauge wired through the door jamb?
      PS I have no door speakers. no power locks.. just these two wires needed.
      67 Camaro In progress
      Dec 2019
      Had to do it on my 68 Chevelle. Compared to the factory hole, it's small. The factory power window s boot was a 2" hole.
      Jan 2018
      Saint Louis, Missouri
      Most of them are sized so that the connector on the end of the wires can be unplugged off of the motor in the door and then the wiring pulled out of the door should the door need to come off and that way you are not cutting wires which would then have to be spliced back together or a new multipin end put on.
      While you might not ever run additional wires through a door jamb boot, if it's a little over sized, who would care. It's not like you see this tube all of the time.
      Another option is to put the two wires in some heat shrink tubing, then shrink it down and then find a rubber grommet that would fit snug around it and then put that size hole in the cowl side and door side.
      I saw your other post and I think the doors have to come off unless you really want to fight things. Also once the holes get made, seal the bare metal edges to keep any rust from forming.
      Jim
      Oct 2007
      Quote Originally Posted by Jim Streib View Post
      Jim
      Thank Jim.. you i will buy new manual regulators before i take these doors off LOL
      https://www.amazon.com/Klein-Tools-5...oghydr-20&th=1 might help
      Feb 2011
      dallas, tx
      Get a step bit and drill it out. It’s pretty simple. I did all of this with everything in the doors and the doors on
      Oct 2007
      Quote Originally Posted by icemanrd19 View Post
      Awesome thats the news I was waiting to here.. If you have a chance and can post a pic form the door jam.. I would really appreciate it..
      Feb 2019
      Kankakee IL
      I should have remember these sooner. No wires to run.
      https://www.dakotadigital.com/index....rod/prd103.htm
      Tracey
