    Results 1 to 15 of 15
      Feb 2012
      Mocksville, NC
      K member frame bolt hole repair
      So my tubular K member decided to take a crap and when it did, one of my bolt hole mounts got bent. I drop the member and the hole is now cocked and concaved and the nutsert broke loose. Is there a tool like a slide hammer that will go into a 1” hole, secure itself on the wall and then I can beat it out? The frame is boxed and is a unibody and I only have access through the 1” hole. Any help is appreciated.
      1968 Charger R/T, EFI,SC,6-speed
      May 2010
      kitchener,Ontario,Canada
      Pics would help , sorry not a big mopar guy to know what you're referring to
      Ryan Austin
      On twitter @raustinss
      On Instagram austinss70
      Feb 2012
      Mocksville, NC
      Here’s a pic.
      May 2010
      Not sure if you want to but I'd cut a hole in the side to access it , reweld it then weld the access hole closed again
      Ryan Austin
      Jun 2020
      Denver
      Do they make rivnuts that big. If they do it’s a pretty easy fix.
      Feb 2012
      Mocksville, NC
      I've found some in that size but the 1" hole in my frame is too big for the rivet. Plus to compress a rivet of that size would require me to have Hulk strength so I was told.
      May 2010
      Also not sure youd want a subframe being held on by rivnut
      Ryan Austin
      Feb 2012
      Mocksville, NC
      It’s a Dodge unibody so everything is tied in. Granted the nutsert would be the weakest link between the other 3 bolts, I don’t think it would be that bad. When the k member welds failed it did damage to that one area.
      Sep 2007
      What's the story on the tubular K-frame crapping? What happened? What brand was it?
      Feb 2012
      Mocksville, NC
      This was a complete setup from Magnumforce Racing. Came with tubular k frame, upper and lower a-arms, rack and pinion, spindles, 13” Wilwoods and coilover shocks. I was told this was good for the street and drag racing. I make a 3mph turn around in a parking lot and the weld snaps and the car drops the driver side. Since this design is 15 years old, they don’t have any replacement k members so I have to buy a whole new setup. And I mean nothing will bolt on to the newer stuff. 2020 can kiss my ass!!
      Jun 2020
      Denver
      What about through bolting all the way through the frame. I’m just thinking how to fix this without cutting a piece out of the frame to straighten it and weld a nut in there and then reweld the pieces back in.
      Feb 2012
      Mocksville, NC
      Interesting. Didn’t think of that. Thanks for the input brother.
      May 2010
      If you go that route you're going to want to "sleeve" the hole by welding in a DOM piece of tubing so you could tighten the bolt without crushing aka collapsing the original rail
      Ryan Austin
      Feb 2012
      Mocksville, NC
      Oh yeah definitely. Good thing I work in a machine shop.
      May 2010
      Lol ...love when you have the skills and the material , good luck
      Ryan Austin
