      Feb 2015
      Country Flag: Sweden
      Help choosing master cylinder. Camaro -68 Wilwood
      Hi!
      Im putting my car together and have almost gotten to the brakes. I have new and unused wilwood 6 piston dynapro calipers in the front and 4 piston dynalite for the rear. Both will be grabbing 12.19" discs.
      The thing is I have no idea what bore and stroke my MC has (looks like original GM power assisted) and if it will work the way I want giving me a firm brake with "feel".
      Do you recommend a proportioning valve to balance front and rear bias? Are there any great upsides to a wilwood MC besides the look and if so, what bore would you reccomend?
      My existing MC
      Jan 2020
      Northern VA
      I would get a new master, just my personal opinion. You will absolutely need a proportioning valve. I would recommend a 15/16" or a 1". Those should give you a firmer pedal even with vacuum assist. BUT, give Wilwood a call and see what they recommend for a bore size.
      Feb 2015
      Thanks BBScott! I suspected I perhaps needed to go that route.
      Oct 2014
      DFW, Texas
      You'll need to know your pedal ratio if you plan on calling Wilwood. Otherwise they'll likely just give you an applicable range.
      1972 Plymouth 'Cuda - Not LS-swapped, 5.7L Hemi [MS3 Gold Box], T56 Magnum 6-speed - 'Cuda Build Page
      1976 Dodge D100 - Warlock
      2016 Subaru WRX - E30 Tune
