    Results 1 to 8 of 8
      Jul 2020
      C.T
      ZZ4 - Lt1 T56 Flywheel? Help!
      So I have a ZZ4 gm crate engine for my 86z28 and a 94z28 donor car, from what I read the ZZ4 and the Lt1 are 1pc RMS.. Will the Lt1 Flywheel work with the ZZ4/t56? if not anyone know what flywheel would? Also a decent clutch?
      Aug 2012
      Peoria, AZ
      I use a 1994 Camaro LT1 flywheel on my HT383 which is also a 1 piece rear main seal. Bolts right up.
      I used the stock LT1 clutch for a while, then tried a RAM 500 hp clutch that didn't last long and settled on a Mcleod Street Extreme kit that has been rock solid.
      https://www.mcleodracing.com/index.p...lutch-kit.html
      This clutch setup is a bit of a strange duck the way it pulls on the throwout bearing rather than pushes on it. Just be aware it's an oddity.
      One other thing is you'll probably have to clearance the front edges of the fork or it'll contact the edge of the pressure plate and it wouldn't hurt to shorten the stand the fork pivot attaches too as well. The new replacement pressure plates are a bit thicker than factory and the fork will contact the plate before the clutch releases. It's a very common issue with all of these LT1 clutch setups.
      Lance
      Eastern Virginia
      1986 was the first year for one piece rear seal, so if you have transmission parts for a 94 Camaro, you will be good. You will know as soon as you try to bolt it on. If is not compatible, it won't go on, bolt circle is different.
      Scot
      86 Monte SS
      Jul 2020
      C.T
      Ok awesome thanks for the info..I’m sure that clutch is great and all, but at almost $900 I was hoping for one cheaper. My engine has 350hp/400tq and that’s at the crank. I have a cam, and plan on a few upgrades but most I’m expecting is 400hp range at crank. Something alittle better than stock I would assume to be ok?
      Aug 2012
      Peoria, AZ
      https://www.summitracing.com/parts/mcl-75316 $692
      I killed the Ram Clutch in less than 2 seasons of autocrossing with my 340 hp, 430 ft lb HT383.
      Lance
      Quote Originally Posted by GeneralLee-01 View Post
      Rockauto lists many options for stock style clutches, which if you are just driving around, should be fine.
      Jul 2020
      C.T
      I’m not Drag racing, just a weekend driver I beat on here and there. I see clutches even on summit that say up to 500hp or 550hp for like $300. This one (good reviews) says could hold up to 490hp and 510ft (remember I have 350hp/408tq@flywheel, which May go up to 400hp near future) $211.00. : https://www.summitracing.com/parts/s...t/model/camaro
      Go for it. I bet it will drive real nice with that clutch.
