    Results 1 to 9 of 9
      Sep 2019
      Country Flag: New Zealand
      69 Camaro on 18's
      Hiya all, I know there's plenty of threads on Camaro's on 18's, but does anyone have the same/similar set up as this?
      Art Morrison IRS & Art Morrison GT Sport C6 IFS in a 69 Camaro
      Minitubs in the rear, & Speedtech wide front tubs up front.
      AME's guidance shows 295/35/18 working on the rear, anyone got a 315/30/18 in there?
      And how wide can you run on the front before problems? If you can fit a 315/30/18 is it practical or just too wide?
      Thanks, Willy
      Jun 2015
      Not sure if this will help but I have a somewhat similar setup and just ordered rims.
      -No Limit Sniper IFS front subframe
      -Anvil Auto deep front inner tubs
      -Art Morrison triangulated 4 link rear end
      -Mini tubbed
      I spec'd out these sizes for my setup:
      Front:
      -18"x11" - 8" of back spacing - 315/30R18 toyo R888R
      Rear:
      -18"x12" - 8" of back spacing 335/30R18 toyo R888R
      I realize we have different suspensions but after measuring my setup, I'm confident this will fit nicely under my car. You may want to get everything mocked up and check your turn radius and clearances from fender to fender. It's worth measuring 2-3 times and making sure you've got the right clearances.
      I did roll the rear fenders just to be safe and avoid cutting those toyos out back.
      Nice setup and good luck on the build!
      Oct 2007
      i am at 335 30 18.. but i will say wish i had 19's tire selection on 18's is slim
      67 Camaro In progress
      Sep 2019
      Quote Originally Posted by Brocal View Post
      -Mini tubbed
      Front:
      Rear:
      Thanks, that's really helpful. I'll have the suspension under the car in a couple of weeks & will measure it up, just trying to get a head start because it takes so long to get wheels from the States to NZ
      Good input,
      Sep 2019
      Quote Originally Posted by XLexusTech View Post
      Hey thanks, I hear you on the 19's & tyres, but I'm trying to stay with 18's. See how it goes,
      Oct 2008
      Seattle, Wa
      I was able to fit 315s up front with the AME subframe with stock inner and outer fenders (I did have to roll the fenders). I track the car pretty regularly and only rub inner fenders on occasion. No problems on the street. I think you should be fine up front.
      1969 Camaro - LS7/T56 - Art Morrison Front Suspension/Ridetech Coilovers
      Instagram: @rbreezee88
      Sep 2019
      Hey that's helpful Ryanater, have you got your wheel specs handy?
      Backspace etc?
      When I die don't let Nina sell my car for what I told her it cost to build.
      Oct 2008
      Seattle, Wa
      Don't go blindly off of these specs because I'm going off of a few random notes I have from a few years back. Looks like I'm running an 18"x10.5" with 6.5" backspacing in front.
      Sep 2019
      Quote Originally Posted by Ryanater View Post
      I'll be measuring up anyway, but that's a start, thanks,
