      May 2015
      Island Lake, IL
      Mild Built 1979 W72 Pontiac 400
      After a personal deal falling through, I have decided to post my Pontiac 400 on the public forum. This is a mildly built combination but it makes awesome power. It actually makes more power than my stock LS1...no joke there. I previously had an aftermarket intake on but I have been in the process of putting a stock intake back on. That is why the intake and valley pan look ugly. I have roughly 7k miles on this combination....not that much run time. Great for anyone trying to restore a '79 400 W72 Firebird or someone simply wanting a strong street engine. I did this build in about 2010 and I roughly put $4k in this setup at the time. This will be intake to oil pan (no carb or ignition) with front accessories.
      Also, this is from a non-air conditioning car so it has the metal hose bracket rather than the a/c components. Another difference over the a/c cars is it has a straight fan without a fan clutch.
      Bottom end...
      1979 PWH Code block
      +.030" KB Forged Icon Pistons
      ARP rod bolts on stock rods
      Top end...
      6X-4 heads milled to 87cc combustion chambers
      Converted to screw-in rocker studs with locks on the stock rocker arms
      Lunati Voodoo series cam shaft
      $2500
      Untitled by Jonathon Randolph, on Flickr
      Feb 2013
      Just sent this to a guy on another forum looking for a 400. Have a good 4th man!
      Ridetech Suspsension
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
      May 2015
      Island Lake, IL
      Quote Originally Posted by Josh@ridetech View Post
      Cool! Thank you sir!
      I hope the build is going well and still making progress btw!
      May 2015
      Island Lake, IL
      Still available.
      I popped off the valley cover to show it still looks brand new inside and then did some detailing on the outside. Again, this is a well built engine.
      Also, I forgot to mention in my initial post that it has an aluminum Flow Kooler water pump.
      May 2015
      Island Lake, IL
      Sold!
