      May 2008
      Chicago
      1980 F body master cylinder and booster
      I was wondering if anyone had any input on a master cylinder and small booster to use on a 1980 Trans Am. The car has all factory equipment, discs up front and drums in the rear. The car will have 4 wheel discs at some point.
      The master is shot and I would like to go with a small booster and a new master. Just wondering if anyone has used the newer plastic ones with a small booster. Thanks
      Jun 2010
      Deployed
      You can use the 1981 TransAm 4 wheel disc set-up. Its reservoir is plastic and the correct application version's MC is aluminum.
      1970 Camaro/DSE build
      May 2008
      Chicago
      Will it work if the current setup is rear drum?
      Quote Originally Posted by kochevy67 View Post
      I don't see why not...
      Instagram @projectgattago
      Dr. EFI
