    Page 3 of 3 FirstFirst 1 2 3
    Results 41 to 58 of 58
    1. #41
      Nov 2004
      Paso Robles Ca.
      Awesome build !!!
      I'm a little biased, but GREAT choice on the wheels. haha
      1969 Camaro
      1957 Chevy 150 Utility Sedan
      2016 MB AMG-s wagon
    2. #42
      Sep 2019
      Country Flag: New Zealand
      Quote Originally Posted by Senek67RS View Post
      Have you figured out where you will be putting your remote PS reservoir? Running the same front drive on an LSA swap and running out of room...
      We'll be on that soon, I'll post a photo
      - - - Updated - - -
      Quote Originally Posted by Aschle View Post
      Awesome build !!!
      Very nice!
      When I die don't let Nina sell my car for what I told her it cost to build.
    3. #43
      Sep 2019
      Well here's where we are currently.
      Still a work in progress, but I think it will work.
      It's a right hand drive car & rack, but it shouldn't make too much difference?
      It was looking really tight for the air intake to get past, so we've recessed the mount panel for the reservoir & the radiator overflow tank (recessed from the rear, so they actually move forward)
      Hope it helps?
Size:  240.7 KBName:  PSC1.jpg
Size:  302.8 KBName:  PSC3.jpg
Size:  457.3 KBName:  PSC5.jpg
    4. #44
      Sep 2019
      And here's a pic with a dummy intake hose
      So hopefully, it'll be something like that, and maybe all the sh*t will fit in.
      But yes, it's definitely getting crowded in there. Maybe a Chevelle would have been a good idea! :-)
    5. #45
      Garden Ridge TX
      In case you didnt know, Those PSC resevoirs work great but the -10 outlet has to be above the power steering pump inlet to flow properly and not starve the pump. In other words, the fluid has to have a downhill run to the pump.
      Hope this helps,
      Evan Q.
    6. #46
      Sep 2019
      Quote Originally Posted by EVO View Post
      Hope this helps,
      Evan Q.
      Aha! OK thanks for that, the outlet is about an inch higher, that enough?
    7. #47
      Garden Ridge TX
      Might be enough, If it isnt, the pump will be kinda noisy and make groaning noises. I used the same one on my son's C10 and its mounted much higher. I'd go for maximum height if hood clearance allows.
      E.Name:  F762E554-B7C5-4178-8F1E-1F1957F8F123.jpg
    8. #48
      Sep 2019
      [QUOTE=EVO;1378476]Might be enough, If it isnt, the pump will be kinda noisy and make groaning noises. I used the same one on my son's C10 and its mounted much higher. I'd go for maximum height if hood clearance allows.
      Ok got it, thanks!
    9. #49
      Sep 2019
      Still moving along. Getting more exciting!
Size:  297.1 KBName:  13.jpg
    10. #50
      Jul 2019
      Ohio
      Quote Originally Posted by mistral View Post
      Hope it helps?
      I like what you are doing with the filter location and size, what filter is that?
    11. #51
      Sep 2017
      I see you got a C and R radiator. I love mine it cools well.
      Your build is looking fantastic..I know they are slow but you can see progress.
      Keep it up.
      TANKMASTERJ
      Jasons Toys
      2000 HD Softail
    12. #52
      Sep 2019
      Keep it up.
      Thanks Pal, still moving ahead!
Size:  337.9 KBName:  15.jpg
    13. #53
      Sep 2019
      Still moving on!
    14. #54
      Sep 2019
      Well, it's been a while but we're getting close now. Runs & drives, needs upholstery & the dash finishing, then front & rear glass in & we're done.
    15. #55
      Jun 2017
      Utah
      This must be very exciting. I can’t wait to be at that point.
    16. #56
      Sep 2019
      Quote Originally Posted by Threepointtwo View Post
      Yep started in 2019, first bits ex Art Morrison arrived early 2020.
      Long road, but it's looking gorgeous.
      Hang in there, if it was easy every Muppet would be doing it!
      I just can't help taking on really ambitious projects.
      Here's the next stroke of madness!
    17. #57
      Jun 2023
      Very cool build. Nice job! Do you have any details on the wheels?
    18. #58
      Sep 2019
      Quote Originally Posted by JJ 86 View Post
      Budnik Vapor, Brushed Rim Outers with Charcoal Center, Fat Lip
      18x10 with 6.5bsp
      18x12 with 7.0bsp
      Vapor - BUDNIK
