    Results 1 to 16 of 16
      67 Cougar rear quarter replacement
      As some of you know, I had a little mishap with my Cougar back in January. I have since settled into my new place in Kansas City and I would really like to fix the rear quarter panel. I took it to a place locally and while I think they will do a good job, it won't be cheap.
      So...I thought about doing it myself. Here is a picture of the damage:
      Full quarter panels are available from Dynacorn are the word is that the quality is good.
      The problem is that I have never done any sort of body work. I have a TIG and I am actually not opposed to buying a MIG for this project.
      My question is, where do I start and how to proceed...If any experienced body guys can chime in, I would appreciate it.
      Instagram @projectgattago
      Dr. EFI
      Oct 2015
      A tig would work fine. Is it a full 1/4 with the sail panel? Basically look at where the new 1/4 will be aTtached and cut the old one off, drill out a ton of spotwelds and fit the replacement. I think full 1/4’s are easier than the smaller ones as you have a lot less welding.
      My half a$$ed build thread.https://www.pro-touring.com/threads/...elle-6-0-4L60E
      Tighten it till it strips & back it off a quarter turn.
      It is a full quarter panel (what's a sail panel?):
      http://www.dynacorn.com/ShowItem.aspx?item=3848B
      I know that I will also need the outer wheelhouse as well as the panel that closes off the rear of the quarter:
      http://www.dynacorn.com/ShowItem.aspx?item=3848D
      Dr. EFI
      Feb 2019
      Kankakee IL
      I think with your attention to detail you could pull it off. Like anything else it's measure twice, or more, and cut once. If you measure the good side you can transfer it to the damaged side.
      Tracey
      Dec 2018
      The sail panel is the b pillar on your car. The part where the roof and quarter meet.
      Quote Originally Posted by Tim C View Post
      Thanks for the clarification. The Dynacorn quarter panel does have a sail panel.
      Dr. EFI
      May 2008
      Chicago
      See if AMD makes a panel, the quality is far better than any others out there that I have seen.
      Nov 2015
      South Jersey
      I know this is jumping ahead but how will you finish the panel? Are you going to try and match the patina?
      69 Cougar
      Schwartz Chassis
      5.0 Coyote
      T-56 Magnum 6 Speed
      Baer Brakes
      Nov 2010
      Ventura County CA
      Now would be the perfect time to go wide body - just sayin'.
      Subscribed
      Quote Originally Posted by kochevy67 View Post
      AMD doesn't have what I need.
      Quote Originally Posted by lxg44 View Post
      There is no matching the patina. I'm not sure what I will do...
      Quote Originally Posted by TheBandit View Post
      Subscribed
      Maybe...lol...
      Dr. EFI
      So....I think I will do one of two things...1. replace it myself, or 2. just beat the dent out...
      If I was to "metal work" the fender, any tips?
      Dr. EFI
      Dec 2018
      Get a book called "The Key to Metal Bumping". Its still available, I just heard about it earlier this year when I started trying my hand at body work on Dad's c10. I bought a copy. It's an old printing, black and white photos of 40s and 50s cars. Lots of details on how to work out dents for the least amount of "lead work"
      Thanks! Ordered.
      Dr. EFI
      Feb 2019
      Kankakee IL
      That is some huge damage to try and work out. If you factor in the hours to even try you'd come out ahead by buying a new quarter.
      Tracey
      Sep 2001
      Accord, NY
      If possible, there's nothing like saving what's there and keeping the character of that great car! Looking forward to your journey here.
      68 camaro - SOLD
      Oct 2015
      Full quarter would be easier than beating that out. You will need to pull the back glass out also.
