Results 1 to 13 of 13
Thread: High Temperature
06-20-2020 #1
High Temperature
I have a 69 Camaro with a 350/700R4. Lately it’s been running warmer then I remember. I changed the thermostat to a 180 degree and it helped but still running warm, 199-210 degrees. I installed an aluminum radiator 10 years ago, converted to electric fans (pusher and a puller), and have 2 different temperature gauges. I know I changed the water pump a few years back as the Wieand aluminum water pump started leaking so I went with the old cast iron water pump. Fans are coming on as designed. Any suggestions?
06-20-2020 #2
