Results 1 to 7 of 7
Thread: Wilwood brake system dragging
06-14-2020 #1Registered User
- Mar 2011
- 28
wilwood brake system Dragging.
Driving my car for the 1st time with a new brake system from wilwood , 6piston front ,4piston rear , 1” master cylinder and 8” dual brake booster. Started the car let it warmup peddle goes down 1/4 to 1/2 way down at the start . Then driving the car for about 15mins,it get back home and can feel the brakes dragging enough to stop the car at a slow speed . Talked to a tech at wilwood and he said check that the calipers are centered on the rotors . I did find the rear rotors were not sitting flush on the axle fixed that and double check the caliper was centered drove it again with the same results. Any help would be appreciated.
06-15-2020 #2
