    Page 6 of 6 FirstFirst 1 2 3 4 5 6
    Results 101 to 115 of 115
    1. #101
      Austin, Tx
      ~15HP and ~10 ft-lb. But how it carried the power was a bigger difference. We stopped the pull at 7500rpm, and that was the peak power point (it was almost flat from 7000-7500). With the 4150, the pull peaked around 6900-7000 and started rolling off. (I can't find the exact plots unfortunately or I would post).
      Bryan (a.k.a. Carbuff)
      70 Camaro RS Hunk'o'Metal - Previous Project
      71 Firebird Project T.O.W. - New Project
    2. #102
      Quote Originally Posted by carbuff View Post
      What was the engine combination?
      Instagram @projectgattago
      Dr. EFI
    3. #103
      Austin, Tx
    4. #104
      Nov 2015
      Andrew, I got the car out today and its running so well. The things acts and behaves like a new car. It's always nice to drive a 50 year old car that runs like a 2012 mustang
    5. #105
      Quote Originally Posted by Thatorange67 View Post
      Awesome!
      Dr. EFI
    6. #106
      Feb 2006
      Arizona, Phoenix area
      Hey i'm all in on the discussion because i'm a potential "victim" of my own engine set up based on what was described. I'm using a Mast 4500 flange intake with Acufab throttle body. I drove it mostly on the track for a year and loved the way it ran but on the street i realized there was no effort in fine tuning it at idle and I realized they just set the idle at 1100rpm. In the test cell a Holley rep was actually there tuning it, here's where i suppose i should've asked more questions. While we were elated with the 750hp pulls i should've also focused on the idle tune. Since then the car has been painted and i'm putting it back together and i'll be "attempting" to figure out the " huge cable throttle body" .....story to be continued.
    7. #107
      May 2016
      Bay Area
      Glad to hear you're a fan of DBW when using a larger TB. I have an LS7 being built now, Holley Sniper intake Nick Williams 102mm TB with DBW should make ~700hp at the crank. Custom ground Comp cam, Callies crank, Callies rods, Brian Tooley valve train, custom ported LS3 heads. Went with the NW TB because I've read rave reviews on the product and choose the DBW set up based on my builders recommendation.
      Public Service Announcement for today:
      For the love of God, please do not use a huge cable throttle body unless your engine combination absolute demands it, in the higher RPM range. And even then, carefully evaluate how your vehicle will be used and determine if a few extra HP are worth the tuning and drivability issues that these big throttle bodies cause! Be extra mindful if you have a manual transmission car, because they are especially vulnerable to the negative effects.
      - - - Updated - - -
    8. #108
      Jul 2012
      PM sent
    9. #109
      Hildebran, NC
      Bump for 2021!!
      I will support all of the other shout-outs for Andrew.
      He got my tune under control, and has everything running great!!
      Five stars!
      I wired everything and did the tuning wizard on the holley.
      It would run, but would not idle below about 1300rpm.
      That is where Andrew picked it up.
      He had a base tune ready and made several tweeks to get it dialed in.
      It only took two sessions to get this thing dialed.
      He explains everything as he goes, and has taught me a lot.
      He was flexible on scheduling on my time and got me in quick.
      Truck starts and idles great, cold or hot.
      Engine is super responsive at all RPMs.
      It pulls like it is going to throw the bed off...LOL
      If anyone is interested, this is my combo...
      1976 Squarebody Truck
      Drivetrain is a 2007 L92 and a 2006 4L80e. (3.40 Ratio Rear)
      I used the Holley Terminator Max Kit 550-928.
      I used the Holley 12-308 fuel module in a new factory tank.
      Factory L92 injectors.
      Modifications are BTR stage 3-V2 truck cam, Circle D 2600-2800 stall, and Speed Engineering 1-7/8" headers.
      It has the factory L92 intake and DBW Throttle Body(87mm), and I have the 10379038 CTSV pedal that Holley recommends.
    10. #110
      Randy,
      Thanks for the review. I really appreciate your kind words!
      Dr. EFI
    11. #111
      Jan 2020
      UT
      Throwing my belated review of Andrew's services out there.
      He was great in working with me to dial in my '71 Cutlass (with original tired Olds 350) before going to the Salt Lake Goodguys show in July. He was great in helping with the physical setup of the vacuum lines and timing advance along with the actual tune to try and get the engine running as smooth as it could. Considering the engine came with the car and showed all of its original miles he did as much as he could without physically fixing internals.
      The car ran good, but still had a light miss and blow by that I needed to take care of since EFI obviously won't magically fix those issues with the engine no matter how good the tune is.
      Recently, I ended up running a half a bottle of Berryman's down the throat of the throttle body. And won't you know, the heads/rings must have been gunked up something fierce. Drove around for about an hour heat cycling and she is smooth as silk now with the tune. Only thing left is to do some power pulls to let the computer map the fuel for 8 functional cylinders.
      Much thanks for all your help Andrew!
    12. #112
      Quote Originally Posted by Fierbird67 View Post
      Glad to help. Email me when you are ready for a tune review!
      Dr. EFI
    13. #113
      If anyone is going to LS fest in Bowling Green, I will be offering live tuning sessions on a first come first serve basis. I will also be offering a discount if you book a slot in advance. I will be arriving in BGKY on the afternoon of Thursday, September 9th and will leave on the morning of Monday, September 12th. Please email me to book a slot and to discuss the details.
      Email: projectgattago at gmail dot com
      Dr. EFI
    14. #114
      Bump for LS fest tuning appointments.
      Dr. EFI
    15. #115
      Oct 2020
      Central Valley, Calif.
      How did it go at LS Fest?
