    Page 4 of 6 FirstFirst 1 2 3 4 5 6 LastLast
    Results 61 to 80 of 115
    1. #61
      Newbury Park, CA
      Unfortunately, the Sniper does not have the required pwm- output as an option. If you have not purchased a system yet, I would highly recommend going with the new Terminator X Stealth. It uses the Terminator X ECU, which does have the PWM- output available. Better still, do a multi-point system using an Edelbrock EFI intake, couple that with a dual-synch distributor, and Terminator X ECU, and have a fully sequential system on your Pontiac engine.
      Can the Sniper output a 0-5v signal based on engine temperature? Example:
      185* = 1.5v
      190* = 1.7v
      195* = 1.8v
      Etc.
    2. #62
      Quote Originally Posted by Mr Nick View Post
      Andrew, do you have the pins/plugs necessary to shorten the universal harness that come with the Sniper, to a specified length?
      I don't sell any hardware. What exactly are you trying to do?
      - - - Updated - - -
      185* = 1.5v
      190* = 1.7v
      195* = 1.8v
      Etc.
      Nope. The Sniper has 4 outputs that are simple ground side triggers.
      Instagram @projectgattago
      Dr. EFI
    3. #63
      Feb 2013
      Andrew was awesome with my car. Extremely helpful and answered all of my stupid questions . I actually need to send him a message again! lol
      Ridetech Suspsension
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
    4. #64
      185* = 1.5v
      190* = 1.7v
      195* = 1.8v
      Etc.
      The HP and the Dominator ECUs can be configured to output a pwm+ signal, which would effectively do this, if the duty cycle math was figured out.
      Dr. EFI
    5. #65
      Mar 2015
      Hi Andrew I have a 68 camaro with a 540 using Holley HP. Would like to see if you can help me get this running right.
    6. #66
      Quote Originally Posted by KCR View Post
      Hi Ken.
      I responded to your PM. Thanks for the interest.
      Dr. EFI
    7. #67
      Jul 2012
      Iowa
      How does the mail tune in process work? I have a sniper on a 300hp ish sbc, its nothing fancy. Its hard to start , doesnt matter if its cold out or hot. I have to cycle the key 2 or 3 times and wait till the pump is done priming to get enough fuel in the system to start. Been messing with it for almost a year now and I honestly just want to throw the system in the trash.
      Miles Boyer
      The car hobby is dangerous,if the speed doesn't kill you, the cost of parts will.
      91 V8 S10
      88 Cutlass Pro-Tour
      97 Chevy lifted Z-71
      96 Corvette
    8. #68
      Quote Originally Posted by silvermonte View Post
      Miles,
      I just sent you a PM.
      Dr. EFI
    9. #69
      Feb 2007
      Tinley Park, IL
      - - - Updated - - -
      I'd like to shorten the 'one size fits all' harness to a specified length so it fits better in the engine bay. I'm not looking to buy hardware. I'd like to send the harnesses to a professional to be shortened.
      Nick ~
      1969 Cutlass
    10. #70
      Nick,
      I sent you a PM.
      Dr. EFI
    11. #71
      Newbury Park, CA
      Can the pwm signal voltage be fixed to a specific voltage, say 5v or 12v? If so, this will be super easy to use with a PSM fan controller.
      Perhaps also build in tables that can control the fan when the AC is on as well?
      The HP and the Dominator ECUs can be configured to output a PWM+ signal, which would effectively do this, if the duty cycle math was figured out.
    12. #72
      The PWM+ output is 12 volts. From there the fan control strategy can be configured in many ways and can certainly include the AC, VSS, and even oil temperature. It's just a matter of having the data as inputs to the ECU.
      Dr. EFI
    13. #73
      If anyone needs some help, please reach out.
      Dr. EFI
    14. #74
      Oct 2020
      Colona, Illinois
      I could use your help on my ls swapped 1988 trans am. It has a lq4, th350, 9” 4:11 gears, Holley hp. What is needed so you can remote tune it?
    15. #75
      Quote Originally Posted by Oldsmoboogie View Post
      Sending you a PM.
      Dr. EFI
    16. #76
      Jan 2020
      Northern VA
      Andrew,
      I sent you a PM
    17. #77
      Quote Originally Posted by Bigblockscott View Post
      Andrew,
      I sent you a PM
      Sent you an email.
      Dr. EFI
    18. #78
      Halloween bump to the top :-)
      Dr. EFI
    19. #79
      Nov 2015
      I sent you a pm. I'd love for you to tune my car now. Its in need if your help.
    20. #80
      Quote Originally Posted by Thatorange67 View Post
      Responded. Thanks for getting in touch.
      Dr. EFI
