Results 1 to 19 of 19
05-05-2020 #1Registered User
- May 2020
- 52
Wilwood brake system spongy pedal issue
Hello! I am currently battling an issue with my brake system and figured this would be a good place to seek help. I am currently running a wilwood forged narrow superlite 6 piston setup in the front, and their forged dynalite 4 piston in the rear with their 1 inch manual master cylinder and the proportioning valve that comes with it in the kit. When pressing the pedal, it is soft for the first half travel, them gains light resistance at the bottom of the throw. If you pump the pedal once then it has a proper pedal feel. I have both bench bled the master and re bled the entire system several times but nothing seems to be working. I am currently using both front outputs from the proportioning valve (one for each front caliper). The brake pedal pushrod is hooked up in the correct spot (the top hole) and I am currently struggling to diagnose the issue.
